3 Replies Latest reply on May 1, 2013 11:35 PM by AnshuPATIL
    How can I tell the difference between a rasterized (in Illustrator) image and an embedded image?
    ArtistBrian
      Trying to determine via Javascript the difference between a file that has been rasterized in Illustrator and a file that has been embedded in Illustrator.  Best way I could think of was to check the rasterItem.file for the images, but the problem happens when I attempt to check the rasterItem.file of a rasterized-in-Illustrator file, I get the error kicked back "There is no file associated with this image" and it stops the script.
      I'm a relative newbie, and I don't know how to error-handle this.  Anyone have any suggestions?  Is there any other way to tell the difference between the files?
      Thanks in advance!
        • 1. Re: How can I tell the difference between a rasterized (in Illustrator) image and an embedded image?
          ArtistBrian Level 1
          Think I have it figured out with a try/catch statement, but if you have any other suggestions, I'd be more than willing to accept them!
          • 2. Re: How can I tell the difference between a rasterized (in Illustrator) image and an embedded image?
            AnshuPATIL
            var displayErrors = 1;
            var maxLines = 50;
            var bob = "";
            var disp_ar = new Array();
            //the item count object:
            var c = 0;
            var    observed  = prompt("What do you want to explore? i.e.;\r   app (not used before CS)\r   documents\r   activeDocument.pageItems[0]","activeDocument.selection[0]");
            //assign prompt text to actual object;
            //   a side effect of which is,
            //     if the user input is actually a line of executable code,
            //   it gets run here:
            var thisObject = eval(observed);
            try
                for (all in thisObject )
                    c++;
                        //attempt to decypher each sub object
                    try
                            bob= all+"=";
                            bob+=  eval(observed+"."+all);
                            disp_ar.push(bob);
                    catch (e)
                        // if undecypherable, say why:
                        if(displayErrors){
                            bob = all+"="+(e.toString().split(":"))[1];
                            disp_ar.push(bob);
                        disp_ar.sort();
                //decide arbitrary max length of list before switching to tabs.
                if(c>1){
                    // if object has more than one object content:
                    var nicedisp = "";
                    var dispLen = disp_ar.length;
                    // if longer than max, divide by the amount longer than max, so you don't
                    // end up with a dangling variable at the end.
                    var maxNum = dispLen>maxLines?dispLen/Math.ceil(dispLen/maxLines):maxLines;
                    var dispOutput = new Array("");
                    var more = "";
                    var myLoc = 0;
                    for (var x=0;x<dispLen;x++)
                        // add spacing for formatting of line numbers less that 10.
                        if(x<9 ){
                            spc = "  ";
                        } else{
                            spc = "";
                        var thisMod = Math.ceil(x%maxNum);
                        if(thisMod==true && x>maxNum -1){
                            myLoc++;
                            //initialize array slot:
                            dispOutput[myLoc] = "";
                        dispOutput[myLoc]+=(spc+(x+1)+") "+disp_ar[x]+"\r");
                    //show output page(s):
                    var outLen = dispOutput.length;
                    for (var a=0;a<outLen;a++)
                        more = a<(outLen-1)?"   More...":"";
                        alert("Contents of:\r"+observed+"\r------------------------\r"+dispOutput[a]+more);
                }else{
                    alert("Value of:\r"+observed+"\r------------------------\r"+thisObject );
            catch (e)
                //if user is running code from command line, do nothing.
                //if object returns something, show it:
                if(thisObject!= undefined){
                    alert(thisObject);
            //handle spacing for columns
            function makeSpace(num){
                spc = "";
                for (var j=0;j<num ;j++ )
                 spc+="|";
                return spc;
