0 Replies Latest reply on Oct 26, 2007 3:27 AM by DomincP
    Need to reference controls in an Empty swf file ?
    DomincP
      The current beta 2 of FABridge requires you to reference any Flash controls you might want to create dynamically via Javascript in the Empty .swf file first (the example just uses an array to create a reference to each control). Trouble is, if you want to have a generic .swf file that you use for different purposes with different controls, referencing all the possible controls will make the .swf file unnecessarily large (which affects download performance etc.) - can Adobe confirm whether the final release will still require you to reference controls in the .swf beforehand or can controls be referenced dynamically as they are needed ?
