10 Replies Latest reply on Nov 1, 2007 1:18 AM by Peter Grainge
    Command line error with RH 6
    AGsMM
      I imported one X5 project to RH 6 and tried to use command line to generate the chm file, but after Scanning finished, a message box pops up with following message "RHCL.exe has encounted a problem and needs to close. We are sorry for the inconvenience" Then, RH closed. I can compile this project in RH GUI.
      The main reason we upgraded to RH 6 is the command line feature, but now it does not work. I am so sad.
      Can anybody here help me with this problem or give me some clues at least.
      Thanks in advance.
        • 1. Re: Command line error with RH 6
          Welcome to the forum.
          I haven't used the command line method but the first thing I would do in your situation is try to compile the file using the wizard. Make sure there is no general issue with compiling the file that way.
          • 2. Re: Command line error with RH 6
            AGsMM Level 1
            Peter, thanks for your reply.
            Could you tell me where I can the wizard.
            By the way, I can generate chm file for this project sucessfully in RH6 GUI.
            • 3. Re: Command line error with RH 6
              RoboColum(n) Level 5
              Peter was referring to the Single Source Layout wizard but it sounds like you have successfully tried this. This means that the problem appears to be not in the project but in the command line compiler. Can you try creating a new project, creating a single topic and compiling that from the command line? This will prove this theory.
              • 4. Re: Command line error with RH 6
                AGsMM Level 1
                Colum, thanks for your suggestion.
                If it is a new project with one topic, it can be compiled by command line compiler.
                I guess there must be some " stuffs" in my project that the command line compiler cannot handle.
                My project has almost 2000 topics so it is hard for me to figure out which topic that causes the problem. Hope someone here has encountered similar problem and known how to solve it.
                AGsMM
                • 5. Re: Command line error with RH 6
                  What I would do is create a new topic. Import 250 topics and compile. If it compiles, import another 250. Repeat the process until an error is received. Then remove the last 250 topics (it may help to put them into a folder to identify them) and add 50 of them. Compile and repeat the whole process. You'll see where I'm going to with this. The method will eventually identify the offending topic. Once you've got that, you can look at it's content.
                  • 6. Re: Command line error with RH 6
                    Easier to copy the project and trash 250, compile and repeat?
                    • 7. Re: Command line error with RH 6
                      That depends on which 250 topics you pick I fear a discussion on whether you get wetter running or walking in the rain! Argument accepted though.
                      • 8. Re: Command line error with RH 6
                        HKabaker Level 2
                        Here's a method that guarantees no more than 5 or 6 tries, and often works in three or four, depending on the starting number:
                        Work with only the first half. If the problem is not there, work with only the second half.
                        Now that you know which half has the prolem, work with the top half of the bad half.
                        Similarly, when you determine the quarter with the problem, repeat.
                        Soon you have narrowed down the list of suspects enough to look at individual topics. Or keep going until you reach the limit for repeatedly dividing by 2. In practical terms here, that's one topic.
                        Harvey
                        • 9. Re: Command line error with RH 6
                          AGsMM Level 1
                          Thanks Peter, Colum, and Harvey.
                          Finially, I got this problem sovled. :))
                          First, I used your ideas to find the topic with problem. It took me 2 hours. Not too bad.
                          Then I scaned in that topic and digged out the sentences that caused the problem in the Truecode view:
                          <meta name=MS-HKWD content="execution mode">
                          <meta name=MS-HKWD content="trig">
                          I removed above sentences, the problem is gone. I can use the command line compiler now.
                          I don't know how and when these keywords were added into the project. This project was owned to someone else before. I re-added those keywods in the Index tab. Everything goes well. So there is no impact on my project.
                          However, I think the command line compiler should be able to handle this kind of "meta" sentence if the compiler in the GUI can do.
                          Can I think this is a defect of RH6 or it is designed like this, or it is a defect of my project?
                          AGsMM
                          • 10. Re: Command line error with RH 6
                            I agree it seems illogical that the GUI can accept it but not the command line. Go to the Adobe site and type Wishlist in the search field. You will find a bug and feature request reporting form.
