1 Reply Latest reply on Apr 22, 2013 8:25 AM by Minds Eye
    Restrict horizontally
    anjemalo Level 1
      Hello:
      I need to restrict to horizontally my sprite.
      I don't know where to put the code for restriction.
      Can you guide me, please?
      thank you
      Here is the code:
      property pThrowSpan, pMode, pCurrentLoc, pLocList, pMoveAmount
      property pClickDiff
      property sp
      on getPropertyDescriptionList me
        list = [:]
        addProp list, #pThrowSpan, [#comment: "Frame Span of Throw",\
          #format: #integer, #range: [#min: 1, #max: 20],\
          #default: 5]
        return list
      end
      on beginSprite me
        sp = sprite(me.spriteNum)
        pMode = #normal
      end
      on mouseDown me
        pMode = #pressed
        pLocList = []
        pClickDiff = sp.loc - the clickLoc
      end
      on mouseUp me
        throw(me)
      end
      on mouseUpOutside me
        throw(me)
      end
      on throw me
        if pLocList.count > 0 then
          pMoveAmount = (the mouseLoc - pLocList[1])/pThrowSpan
          pMode = #throw
        end if
      end
      on exitFrame me
        if pMode = #pressed then
          pCurrentLoc = the mouseLoc
          sp.loc = pCurrentLoc+ pClickDiff
          pLocList.add(pCurrentLoc)
          if pLocList.count > pThrowSpan then pLocList.deleteAt(1)
        else if pMode = #throw then
          pCurrentLoc = pCurrentLoc + pMoveAmount
          pMoveAmount = pMoveAmount * .9
        end if
      end
        • 1. Re: Restrict horizontally
          Minds Eye
          Depends on when you want the sprite to be restricted to the the horizontal axis. While dragging?  when throwing? Or both?
          If it's while dragging and throwing, you might want to change your code so that it's only using the loch part of the point locations. (e.g. the mouseH, point.locH etc.)
