Hi guys,
As a web designer I need to work with multiple psd files at a time. Once homepage is designed I start designing other substitute pages where I need to use some common modules like header/footer from homepage. Problem occurs when I change something in header from homepage or any other page, which actually needs to be changed from other pages as well. So for big projects where there are 40/50 pages it's impossible to change the header one by one. I was wondering whether there is any way where I can save those common modules(header/footer) as .psd or any other format and use in other pages. If I change that file, it will be changed in all other pages.
In Illustrator this problem is partially solved by placing any image. If I make any changes to that image, it get changed in all other pages where this image is placed.
So if anyone has any solution for this please help.
many thanks
Asif
