I have CF 10,284568 installed on SUSe 12.2 with Java 1.7.0_15 64bit. When I swap out the two JCE files, restart Coldfusion, I can no longer login to the Administrator. To be more specific, it appears session management isn't working. If I login using a bad username/password pair I get an error, if I login with the correct pair I get returned to the login screen without any error. Additionally, none of my datasources work (MySQL ). If I swap out the original (local policy and US export policy jars) and restart everything works fine.
What am I doing wrong? Do I need to run something in the CF bin or reinstall to get this to work?
This has happened to me too. We need to change the local_policy JAR files for stronger crypto and yet if we replace the two JAR files in C:\ColdFusion10\jre\lib\security, then CF Admin does not work and we also get errors elsewhere on our site.
Please Adobe, will you respond and tell us how to update the policy files? We need this to run PayPal payments on our site urgently.
Regards,
Mark
I tried to repro the Issue :
Here are my findings ,
Case 1 )
CF with Java 1.7.0_25
On top of it Install UnlimitedJCEPolicy JDK7
Restart Server
Everything works fine
Case 2 )
CF with Java 1.6.0_29
On top of it Install UnlimitedJCEPolicy 6
Restart Server
Case 3 )
On top of it Install UnlimitedJCEPolicy JDK7 ( Basically wrong version of Policy Files )
Unable to open administrator !! And DB’s won’t work as mentioned above
Case 4 )
On top of it Install UnlimitedJCEPolicy 6 ( Basically wrong version of Policy Files )
Can you please check if you are applying the right version of Policy Files ? Or Am I missing something here ? Can you also try with the latest Java and latest CF Update ?
Regards ,
YASHAS RATTEHALLI
ADOBE CF Engineering Team
Thank you for the response. I managed to get the JCE installed by using the JCE from:
http://www.oracle.com/technetwork/java/javase/downloads/jce-7-download-432124.html
It seems that CF 10 is very particular about the Java version you are using. We are on JRE 1.7, and so only JCE 7 will work. all others fail for us, even recent 1.6. There are many combinations of files, and getting the right one is not easy. Oracle's download page is also awful and does not explain well enough what version their files are for.
Adobe, please create a FAQ to help people with this.
