4 Replies Latest reply on Apr 23, 2013 5:28 AM by VMount
    Data merge frame placement options
    VMount
      Hi
      I'm using data merge for a layout which needs a series of black frames stacked on top of each other.
      If I have a black keyline all the way around, I get a double thickness line between the frames.
      If I have a black keyline around the top and two sides, it works fine apart from the frame at the bottom of the stack as it has a missing line.
      The way to get around it to my mind would be to be able to put a negative measurement between the frames, but it's not an option:
      Any ideas?
