1 Reply Latest reply on Apr 27, 2013 7:30 PM by Sham HC
    Richtext multifield dialog issue
    mdp3 Level 1
      Hey y'all,
      I'm experiencing the following problem when working with a multifield richtext component. I can open the component's dialog fine and add and edit richtext fields. However, once I click ok and close this dialog for the first time, on any subsequent times that I try to open and add/remove richtext fields, the dialog will not close when I click on ok. I've googled around and also on the forums and it seems like this question has popped up a couple of times, but without an answer. Is this a known defect with CQ? I'm using 5.5 and have experienced this problem using IE, Firefox, and Chrome.
      Here are some posts that describe the same issue - though they are trying to use multifields of custom widgets and I'm just trying to use a multfield of a plain OOTB richtext.
      http://www.linkedin.com/groups/TypeError-thiseldom-is-undefined-4003307.S.147700692
      http://forums.adobe.com/message/4882718
