3 Replies Latest reply on Apr 27, 2013 6:13 PM by Ned Murphy
    Tween an array Item
    JonnyDL Level 1
      I built a script that will have movieclips populate the stage. In this case a leaderboard.
      each movieclip created is positioned and put into an Array.
      The problem is getting an array item and being able to tween it
      *i'd like to experiment with different tween combinations to get them off the stage. Here is what I got
      I'm able to get the clips on the stage...Can't get them off =]
      import mx.transitions.Tween;
      import mx.transitions.easing.*;
      Block = new Array();
      var Xposition:Number = 0;
      var Yposition:Number = 0;
      var stack:Number=Math.ceil(Stage.height/30);
      var Numofstacks:Number=Math.ceil(Stage.width/30);
      var fadeit:Tween;
      var n:Number = 0;
      for (r=0; r<(Numofstacks); r++) // 25
                Yposition=0;
                          for (c=0; c<(stack); c++) // 3
                                    var particle = this.attachMovie("block","block_"+r+c ,this.getNextHighestDepth());
                                    particle._y = Yposition
                                    particle._x = Xposition
                                    Block[n] = particle._name;
                                    //trace(particle._name)
                                    Yposition = Yposition + 30;
                                    n++
                          Xposition=Xposition+30
      var runit = setInterval(effcts, 3000)
      function effcts ():Void
                trace("go")
                //for (a=0; c<(Block.length - 1); a++) // 3
                                    fadeit = new Tween(Block[0], "_alpha", Strong.easeOut, 100, 0, 1.5, true);
      clearInterval(runit);
