20 Replies Latest reply on May 3, 2013 3:52 PM by designedbyjackley
    If...else if not working for incrementing global vars and jumping to frame labels
    designedbyjackley Level 1
      The problem I'm having is when I change my simple if statements to "else if" and increment a global variable it actually breaks the original "if". If you swipe left, right or down it increments the global var "animCount" and jumps the to the specific frame label and plays that animation. Then I would like to check if the val of animCount has been changed and if the user swipes again left, right or down it takes aways from the val of "animCount" and I then I have another statement that checks for that and jumps to the a new specific frame label and plays that animation. The problem is I cannot just have a linear version of it moving down the main Stage timeline it actually needs to jump all around to very specific spots.
      Below is the code that I have on document.compositionReady that works but when you add the else if its breaks ... What the heck am I doing wrong!
      Hope someone can please help
      // Working Code ///////////////////////////////////////////////////////////
      // GLOBAL VARS --------------------------------------------
      this.animCount = 0;
      // swipe
      this.swipeStartX;
      this.swipeEndX;
      this.swipeStartY;
      this.swipeEndY;
      this.swipePadding = 60;// prevent swipe when clicking
      // ARROW BTNS --------------------------------------------
      this.onSwipeLeft = function()
                if(this.animCount == 0){
                          this.animCount++;
                          sym.play("anim_4");
      this.onSwipeRight = function()
                          this.animCount++;
                          sym.play("anim_1");
      this.onSwipeDown = function()
                          this.animCount++;
                          sym.play("ice_dunk_1");
      // SWIPE --------------------------------------------
      this.onSwipe = function()
                // swipe right (scrub to left)
                if( this.swipeStartX < this.swipeEndX - this.swipePadding )
                          this.onSwipeRight();
                // swipe left (scrub to right)
                }else if( this.swipeEndX < this.swipeStartX - this.swipePadding )
                          this.onSwipeLeft();
                // swipe down (scrub to down)
                }else if( this.swipeStartY < this.swipeEndY - this.swipePadding )
                          this.onSwipeDown();
      // End Working Code ///////////////////////////////////////////////////////////
      // Bad Code ///////////////////////////////////////////////////////////
      this.animCount = 0;
      // swipe
      this.swipeStartX;
      this.swipeEndX;
      this.swipeStartY;
      this.swipeEndY;
                          this.animCount++;
                          sym.play("anim_4");
                else if(this.animCount == 1){
                          this.animCount--;
                          sym.play("anim_2");
                          this.animCount++;
                          sym.play("anim_1");
                          this.animCount--;
                          sym.play("anim_5");
                          this.animCount++;
                          this.animCount--;
                          sym.play("anim_3");
               this.onSwipeLeft();
               this.onSwipeDown();
      // End Bad Code ///////////////////////////////////////////////////////////
        • 1. Re: If...else if not working for incrementing global vars and jumping to frame labels
          TimJaramillo Level 4
          Hey Jeff, what do you mean it "breaks" the original "if" statement? Are you seeing errors in the console log?
          Can you post your files?
          • 2. Re: If...else if not working for incrementing global vars and jumping to frame labels
            Hey Tim,
            Sorry I should have been more clear on it "breaks". Basically before I put in the "else if" in the statement it jumps to the correct frame but when I add the "else if" it jumps to the wrong frame label right off the bat.
            I wonder if instead of incrementing the variable I should change the value exactly and reference the exact specific number. Like Instead of changing it like this "this.animCount++;" I should change it like this "this.animCount = 3;" and if the variable == 3 jump to the specific frame label??
            sent you a PM with the link
            • 3. Re: If...else if not working for incrementing global vars and jumping to frame labels
              Hey there, I'm still not fully clear on how this interaction works. Below are a few scenarios, let me know what you're trying to do for each:
              User swipes right: you play first "right" animation.
              User swipes right again: you play a different "right" animation.
              User swipes right again: what happens?
              User swipes up: you play first "up" animation.
              User swipes right again: you play first "right" animation?
              User swipes left: you play first "left" animation.
              User swipes up: first "up" animation.
              • 4. Re: If...else if not working for incrementing global vars and jumping to frame labels
                User swipes right: you play first "right" animation "anim_1"
                User swipes right again: you play a different "right" animation "anim_5"
                User swipes right again: loops back to play "anim_1" again and "anim_5" if they swipe right again
                User swipes left: you play first "left" animation "anim_4"
                User swipes left again: you play a different "left" animation "anim_2"
                User swipes left again: loops back to play "anim_4" again and "anim_2" if they swipe right again
                User swipes down: you play first "up" animation. "ice_dunk_1"
                User swipes right again: disable right nothing happens
                Or if User swipes left: disable left nothing happens
                User swipes down: you play second "up" animation. "ice_dunk_2"
                User swipes right again: you play first "right" animation "anim_1" or if they swipe left play "anim_4"
                User swipes left: you play first "left" animation "anim_2"
                User swipes right again: you play first "right" animation "anim_1" again
                User swipes up: "anim_3" animation
                User swipes right again: you play "anim_5" or if the user swipes left play "anim_2"
                hope that makes sense
                • 5. Re: If...else if not working for incrementing global vars and jumping to frame labels
                  Hmmm, the plot thickens ... is it correct to say that the current animation partially determines what the next swipe does?
                  • 6. Re: If...else if not working for incrementing global vars and jumping to frame labels
                    Yeah Totally.
                    Thats why I made specific "in and out" for swipe left and "in and out" for swipe right. If your on the purple shape with the pink shape you have a different swipe down animation than if you were on the solo purple shape. using the global var as a marker to let me know what animation they are on.
                    But right now I can't even get it to jump around to specific frame labels even tho I am pretty sure I have my code structured properly
                    • 7. Re: If...else if not working for incrementing global vars and jumping to frame labels
                      Ok, you'll want to set up a state machine to handle all the different states.
                      What are all the possible "states"- iceberg up, iceberg down, ice thing sticking out, ... etc? List them out for me.
                      • 8. Re: If...else if not working for incrementing global vars and jumping to frame labels
                        "States"
                        • iceberg_up (User can swipe left, right and down)
                        • iceberg_flipped (User can swipe left, right and down)
                        • greensea_creature_up (User can only swipe down and possibly up. Want to disable left & right when in this state)
                        (will possible be adding more "states")
                            • boat_up
                            • beach_up
                        • 9. Re: If...else if not working for incrementing global vars and jumping to frame labels
                          Ok, this should be enough to get you rolling- I set up a state machine, with switch case for "onSwipeLeft" only. You can apply this to the other swipes. Here's a link to the code as well, since the forum sometimes messes up tabbing, making the code really hard to read. Lemme know if you have any questions.
                          link to code:
                          http://www.timjaramillo.com/code/edge/_source/_temp/test.js
                          this.currentState = this.STATE_ICEBERG_UP;// beginning state
                          this.STATE_ICEBERG_UP = "iceberg_up";
                          this.STATE_ICEBERG_FLIPPED = "iceberg_flipped";
                          this.STATE_CREATURE_UP = "creature_up";
                          // swipe
                          this.swipeStartX;
                          this.swipeEndX;
                          this.swipeStartY;
                          this.swipeEndY;
                                    switch( this.currentState )
                                              case this.STATE_ICEBERG_UP:
                                                        sym.play("anim_4");
                                                        this.currentState = this.STATE_ICEBERG_FLIPPED;
                                                        break;
                                              case this.STATE_ICEBERG_FLIPPED:
                                                        sym.play("anim_2");
                                                        break;
                                              case this.STATE_CREATURE_UP:
                                                        sym.play("anim_1");
                                                        break;
                                              default:
                                                        console.log('onSwipeLeft, no matching case');
                                                        break;
                                              this.animCount++;
                                        sym.play("anim_1");
                                        this.animCount--;
                                        sym.play("anim_5");
                                              this.animCount++;
                                              this.animCount--;
                                              sym.play("anim_3");
                                   this.onSwipeLeft();
                                   this.onSwipeDown();
                          • 10. Re: If...else if not working for incrementing global vars and jumping to frame labels
                            That makes perfect sense! Sometimes it takes something like this for you to go "Ahhh why didn't I think of that!" I am going to test that now... it still makes me wonder why the simple else if statements I had were acting so erratic. But either way this allows for expandablity with a simple structure
                            I'll hit you back with the results thx so much for taking the time to help me iron this out!
                            • 11. Re: If...else if not working for incrementing global vars and jumping to frame labels
                              No problem! Whenever you have many different states, and need to do different things dependent on those states, the State Machine, (with switch statements) comes through every time! It really helps to simplify what is otherwise a complicated, hard to follow mess.
                              Btw, can you mark my last post as "Correct", so future users will be able to easily find the solution?
                              Let me know if you have any more Q's.
                              • 12. Re: If...else if not working for incrementing global vars and jumping to frame labels
                                Still testing it out ... I think I need to get some of the frame labels worked out for it to be completly working properly ... I do have one question with the new global variables that were added. Are the states in quotes referencing frame labels? For instance "iceberg_up"  this.STATE_ICEBERG_UP = "iceberg_up";
                                • 13. Re: If...else if not working for incrementing global vars and jumping to frame labels
                                  Naw, the text in quotes don't have anything to do with frame labels.
                                  The "static" variables (STATE_ICEBERG_UP) hold string descriptions (iceberg_up) for each state. That way, if you need to check the state from another js file or somewhere else in your code, you can clearly reference the "STATE_ICEBERG_UP" variable, rather than having to dig through the code to get a random string "iceberg_up".
                                  • 14. Re: If...else if not working for incrementing global vars and jumping to frame labels
                                    Thats what I thought ... Just wanted to make sure. Funny thing is now that I am using the new switch case for the left swipe its no longer swiping left at all?
                                    • 15. Re: If...else if not working for incrementing global vars and jumping to frame labels
                                      Ah- I think I know why.
                                      Reorder the vars to this:
                                      Previously, STATE_ICEBERG_UP was not defined to set this.currentState to it.
                                      • 16. Re: If...else if not working for incrementing global vars and jumping to frame labels
                                        Yeah that makes sense, it didnt know what that was since it was before declaring the actual var.
                                        Its swiping left now but its getting stuck on the first left swipe animation "anim_4" even after it sets it to this.STATE_ICEBERG_FLIPPED; instead of changing its state and using "anim_2" as the 2nd left swipe to case it to loop. Just the same issue I was having with the simple else if statements...
        sym.play("anim_4");
        break;
        sym.play("anim_2");
        break;
                                                            default:
        break;
                                        • 17. Re: If...else if not working for incrementing global vars and jumping to frame labels
                                          Put a bunch of console logs in there to find out what's going on.
                                               console.log("at onSwipeLeft, this.currentState = "+this.currentState);
        console.log("at case STATE_ICEBERG_UP");
        sym.play("anim_4");
        break;
        console.log("at case STATE_ICEBERG_FLIPPED");
        sym.play("anim_2");
        break;
                                                              default:
        break;
                                          • 18. Re: If...else if not working for incrementing global vars and jumping to frame labels
                                            All hail the console log!!! Somehow it was changing it back to iceberg up right after it changed it to flipped. So I added the state change to the stop frame after the actual animation plays and it totally fixed the issue!!!
                                            // insert code here
                                            sym.stop();
                                            Thanks a mill for shedding some light on the subject!
                                            You are the man ... MAN!
                                            • 19. Re: If...else if not working for incrementing global vars and jumping to frame labels
                                              Hmm, odd- not sure why the state would change. The only thing I can think is that it's some kind o' scope issue. The swipe example you're working off of uses "this" to set the scope, while the recommended method is to use "sym" to set scope. (Note that I created that swipe example long long ago, before scope in Edge was clear to me.) In the past I've built complex projects using "this", so it works fine, but using "sym" is a better and more clear way to control scope.
                                              So, ideally, your code would look like this:
                                              sym.STATE_ICEBERG_UP = "iceberg_up";// var that needs to be addressed from another scope
                                              var currentState = this.STATE_ICEBERG_UP;// var that only needs to be addressed from this event scope
                                              // function that only needs to be called from this event scope
                                              function onSwipeLeft()
                                                        switch( currentState )
        case sym.STATE_ICEBERG_UP:
        sym.play("anim_4");
        currentState = sym.STATE_ICEBERG_FLIPPED;
        break;
                                              // function that needs to be called from another scope
                                              sym.onSwipe = function()
                                              And to call "onSwipe" from another scope, for example, you'd use this (same with setting "sym" vars from another scope):
                                              sym.getComposition().getStage().onSwipe();
                                              Anyhow, glad you got it working!
                                              • 20. Re: If...else if not working for incrementing global vars and jumping to frame labels
                                                I decided to update from "this" to "sym" since I thought thats why I couldnt access "onSwipe" from another scope but now for some reason once I updated my "this" to "sym" per your advice the "currentState = sym.STATE_ICEBERG_FLIPPED;" check is not longer working so the animations no longer swipe in the correct order ...
