2 Replies Latest reply on Apr 24, 2013 10:26 PM by BEGINNER_X
    Need all textframes in equal width and height
    BEGINNER_X Level 3
      Hi All,
      Request:
      I need all the text frames in equal width and equal height in my active document.
      Trying code:
      var myDoc = app.activeDocument
      var myTF = myDoc.textFrames.everyItem().getElements()
      alert(myTF.length)
      app.activeDocument.viewPreferences.horizontalMeasurementUnits = app.activeDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.MILLIMETERS;
      for(k=0; k<myTF.length; k++)
          myTF[k].geometricBounds[3] = myTF[k].geometricBounds[1]+125    //Doubt this line
          alert(myTF[k].geometricBounds[3])
      Could anyone give solution for my request.
      Beginner_X
        • 1. Re: Need all textframes in equal width and height
          Jump_Over Level 5
          You can edit geometricBounds as a whole array - not as a particular [x] element. So to change object position use:
               object.geometricBounds = YourNewArray;     //      [y,x,Y,X]
          but in THIS case better way is to use:
               object.resize(
                      CoordinateSpaces.INNER_COORDINATES,
                      AnchorPoint.TOP_LEFT_ANCHOR,
                      ResizeMethods.REPLACING_CURRENT_DIMENSIONS_WITH,
                      [ mWidth, mHeight] );
          Jarek
          • 2. Re: Need all textframes in equal width and height
            BEGINNER_X Level 3
            Hi Jump_Over,
            I got this below lines.
            for(i=0; i<myTF .length; i++)
                myStoreBounds = myTF[i].geometricBounds
                myTF[i].geometricBounds = [myStoreBounds[0], myStoreBounds[1], myStoreBounds[2], myStoreBounds[1]+120]
            Could you suggest or provide any better coding.
            Beginner
