1 Reply Latest reply on Apr 29, 2013 2:28 PM by mk403
    How do I get the Application object for a running instance of InDesign Server from VBScript and C++
    mk403 Level 1
      I have a running instance of InDesign Server CS6 which I launched using the following command:
      "C:\Program Files\Adobe\Adobe InDesign CS6 Server x64\InDesignServer.com" -port 12345
      I tried running the following VBScript file to access this running instance:
      Set myApp = WScript.GetObject("configuration_12345")
      myApp.ConsoleOut("Foo")
      Set myApp = Nothing
      But I get this error (launched using 64-bit wscript.exe):
      Windows Script Host
      Line:          1
      Char:          1
      Error:          File name or class name not found during Automation operation
      Code:          800A01B0
      Source:           Microsoft VBScript runtime error
      I also tried to access this instance using C++ COM:
      int _tmain(int argc, _TCHAR* argv[])
                HRESULT hr = ::CoInitializeEx(NULL, COINIT_MULTITHREADED);
                if (FAILED(hr))
                          printf("COM init failed\n");
                          return 0;
                IDispatch* pUnk = NULL;
                hr = ::CoGetObject(L"configuration_12345", NULL, __uuidof(IDispatch), (void**)&pUnk);
                if (SUCCEEDED(hr))
                          pUnk->Release();
                          pUnk = NULL;
                ::CoUninitialize();
                return 0;
      But, CoGetObject returns 0x800401e4 (MK_E_SYNTAX).
      However, if I use the "helloworld-csharp-com" sample, using "configuration_12345" as the config, it works fine. Why is it not working with VBScript and C++?
      I'm running Windows 8, 64-bit, IDS CS6 8.0
        • 1. Re: How do I get the Application object for a running instance of InDesign Server from VBScript and C++
          mk403 Level 1
          I believe I figured out what was going wrong with my C++ program. My InDesignServer process was running with Administrator-level privileges, but my C++ program was running as at the normal privilege level. So, my C++ program was not able to see the "configuration_12345" object because it didn't have sufficient privileges to see the object. I have it working now and I no longer get errors.
          Oddly, I was not able to get my VBScript to work regardless of the privilege level it was running at. But, I did find a workaround that was good enough for my purposes. If I change the first line from this:
          To this:
               Set myApp = WScript.CreateObject("InDesignServer.Application")
          "myApp" ends up being set to my currently running instance of InDesign Server. I don't know what happens if you have more than one instance of InDesign Server running, but, for my purposes, I'll only ever have one instance running at a time.
