1 Reply Latest reply on Jan 21, 2014 9:28 AM by garrofer
    Problems adding native extensions from linked resources in Flash Builder 4.7
    ajay_p
      While adding native extensions (.ane files) from linked source folder in a Actionscript Mobile Project on Flash Builder 4.7, a java.lang.NullPointerException is thrown. Below is the stacktrace. Any help would be appreciated.
      Also, what is the link/site to file Flash Builder 4.7 bugs?
                at com.adobe.flexbuilder.project.ui.utils.ANE.AppXMLFileANEExtensionHandler.addToAppXMLModel (AppXMLFileANEExtensionHandler.java:78)
                at com.adobe.flexbuilder.project.ui.utils.ANE.AppXMLFileANEExtensionHandler.addToAppXmlFile( AppXMLFileANEExtensionHandler.java:65)
                at com.adobe.flexbuilder.project.ui.utils.ANE.AppXMLFileANEExtensionHandler.addToAppXmlFile( AppXMLFileANEExtensionHandler.java:48)
                at com.adobe.flexbuilder.project.ui.utils.ANE.ANEController.applyWorkingCopy(ANEController.j ava:791)
                at com.adobe.flexbuilder.project.ui.utils.ANE.ANEController.applyWorkingCopy(ANEController.j ava:814)
                at com.adobe.flexbuilder.project.ui.utils.ANE.ANEpathControl.contributeToLibraryPath(ANEpath Control.java:723)
                at com.adobe.flexbuilder.project.ui.utils.AirBuildPathsPropertiesPane.contributeToLibraryPat h(AirBuildPathsPropertiesPane.java:85)
                at com.adobe.flexbuilder.project.ui.utils.AbstractBuildPathsPropertiesPane.getLibraryPath(Ab stractBuildPathsPropertiesPane.java:1344)
                at com.adobe.flexbuilder.project.ui.properties.BuildPathsPropertyPage.applyProjectSettings(B uildPathsPropertyPage.java:520)
                at com.adobe.flexbuilder.project.ui.properties.AbstractFlexProjectPropertyPage.performOk(Abs tractFlexProjectPropertyPage.java:117)
                at com.adobe.flexbuilder.project.ui.properties.BuildPathsPropertyPage.performOk(BuildPathsPr opertyPage.java:617)
                at org.eclipse.jface.preference.PreferenceDialog$13.run(PreferenceDialog.java:964)
                at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
                at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
                at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
                at org.eclipse.jface.preference.PreferenceDialog.okPressed(PreferenceDialog.java:944)
                at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.okPressed(FilteredPreferenceDial og.java:447)
                at org.eclipse.jface.preference.PreferenceDialog.buttonPressed(PreferenceDialog.java:233)
                at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
                at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
                at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
                at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4128)
                at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1457)
                at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1480)
                at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1465)
                at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1270)
                at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3974)
                at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3613)
                at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
                at org.eclipse.jface.window.Window.open(Window.java:801)
                at org.eclipse.ui.dialogs.PropertyDialogAction.run(PropertyDialogAction.java:158)
                at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
                at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionI tem.java:584)
                at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
                at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java :411)
                at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
                at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
                at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
                at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
                at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
                at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
                at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
                at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.ja va:79)
                at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
                at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
                at java.lang.reflect.Method.invoke(Method.java:597)
                at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
                at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
                at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
