1 Reply Latest reply on Jul 8, 2013 3:56 PM by Naveeth_J
    Urls returning error response after CQ5.6 upgrade
    Naveeth_J
      After upgrading to CQ 5.6 we are not able to access any folder through URL.
      I am able to see all the contents of the folder in 5.4, however in 5.6 version i get 403 error if i use the same error
      http://localhost:4502/var/doob/books/styles/
      Forbidden
      Cannot serve request to /var/doob/books/styles/ in org.apache.sling.servlets.get.DefaultGetServlet
      Request Progress:
      0 (2013-04-25 11:17:23) TIMER_START{Request Processing}       0 (2013-04-25 11:17:23) COMMENT timer_end format is {,}
             0 (2013-04-25 11:17:23) LOG Method=GET, PathInfo=/var/doob/books/styles/ 0 (2013-04-25 11:17:23) TIMER_START{ResourceResolution} 0 (2013-04-25 11:17:23) TIMER_END{0,ResourceResolution} URI=/var/doob/books/styles/ resolves to Resource=, type=sling:Folder, path=/var/doob/books/styles, resource=[JcrNodeResource, type=sling:Folder, superType=null, path=/var/doob/books/styles] 0 (2013-04-25 11:17:23) LOG Resource Path Info: SlingRequestPathInfo: path='/var/doob/books/styles', selectorString='null', extension='null', suffix='/' 0 (2013-04-25 11:17:23) TIMER_START{ServletResolution} 0 (2013-04-25 11:17:23) TIMER_START{resolveServlet(, type=sling:Folder, path=/var/doob/books/styles, resource=[JcrNodeResource, type=sling:Folder, superType=null, path=/var/doob/books/styles])} 0 (2013-04-25 11:17:23) TIMER_END{0,resolveServlet(, type=sling:Folder, path=/var/doob/books/styles, resource=[JcrNodeResource, type=sling:Folder, superType=null, path=/var/doob/books/styles])} Using servlet org.apache.sling.servlets.get.DefaultGetServlet 0 (2013-04-25 11:17:23) TIMER_END{0,ServletResolution} URI=/var/doob/books/styles/ handled by Servlet=org.apache.sling.servlets.get.DefaultGetServlet 0 (2013-04-25 11:17:23) LOG Applying Requestfilters 0 (2013-04-25 11:17:23) LOG Calling filter: org.apache.sling.bgservlets.impl.BackgroundServletStarterFilter 0 (2013-04-25 11:17:23) LOG Calling filter: org.apache.sling.i18n.impl.I18NFilter 0 (2013-04-25 11:17:23) LOG Calling filter: org.apache.sling.rewriter.impl.RewriterFilter 0 (2013-04-25 11:17:23) LOG Calling filter: com.day.cq.wcm.designimporter.CanvasPageDeleteRequestFilter 0 (2013-04-25 11:17:23) LOG Calling filter: com.day.cq.wcm.core.impl.WCMRequestFilter 0 (2013-04-25 11:17:23) LOG Calling filter: com.day.cq.wcm.foundation.forms.impl.FormsHandlingServlet 0 (2013-04-25 11:17:23) LOG Calling filter: com.adobe.granite.optout.impl.OptOutFilter 0 (2013-04-25 11:17:23) LOG Calling filter: com.day.cq.theme.impl.ThemeResolverFilter 0 (2013-04-25 11:17:23) LOG Calling filter: org.apache.sling.engine.impl.debug.RequestProgressTrackerLogFilter 0 (2013-04-25 11:17:23) LOG Calling filter: com.day.cq.wcm.mobile.core.impl.redirect.RedirectFilter 0 (2013-04-25 11:17:23) LOG RedirectFilter did not redirect (request extension does not match) 0 (2013-04-25 11:17:23) LOG Calling filter: com.day.cq.wcm.core.impl.warp.TimeWarpFilter 0 (2013-04-25 11:17:23) LOG Applying Componentfilters 0 (2013-04-25 11:17:23) LOG Calling filter: com.day.cq.wcm.core.impl.WCMComponentFilter 1 (2013-04-25 11:17:23) LOG Calling filter: com.day.cq.wcm.core.impl.WCMDebugFilter 1 (2013-04-25 11:17:23) TIMER_START{org.apache.sling.servlets.get.DefaultGetServlet#0} 1 (2013-04-25 11:17:23) LOG Using org.apache.sling.servlets.get.impl.helpers.StreamRendererServlet to render for extension=null 1 (2013-04-25 11:17:23) LOG Applying Error filters 1 (2013-04-25 11:17:23) LOG Calling filter: org.apache.sling.rewriter.impl.RewriterFilter 1 (2013-04-25 11:17:23) TIMER_START{handleError:status=403} 2 (2013-04-25 11:17:23) TIMER_END{1,handleError:status=403} Using handler /libs/sling/servlet/errorhandler/default.jsp 3 (2013-04-25 11:17:23) LOG Found processor for post processing ProcessorConfiguration: {contentTypes=[text/html],order=-1, active=true, valid=true, processErrorResponse=true, pipeline=(generator=Config(type=htmlparser, config={}), transformers=(Config(type=linkchecker, config={}), Config(type=mobile, config=org.apache.sling.jcr.resource.JcrPropertyMap@1d1dcb75), Config(type=mobiledebug, config=org.apache.sling.jcr.resource.JcrPropertyMap@f187d42), Config(type=contentsync, config=org.apache.sling.jcr.resource.JcrPropertyMap@10c77fcc), serializer=Config(type=htmlwriter, config={}))} 4 (2013-04-25 11:17:23) TIMER_END{4,Request Processing} Dumping SlingRequestProgressTracker Entries
