• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Coldfusion AMI in EC2: how to add more web servers?
Community Beginner ,
Apr 25, 2013 Apr 25, 2013
I am currently running an instance of the Coldfusion AMI with linux.
I want to keep that instance and launch 2 more web servers (independent machines) that point to the coldfusion application server.
How can I do this with apache , tomcat, etc?
Views
875
Translate
Translate
Report
Report
Community guidelines
community guidelines
Enthusiast ,
Apr 26, 2013 Apr 26, 2013
If you are looking to have just two additional web servers and a single CF server - you can launch two more linux server instance (does not need to be a ColdFusion AMI, you can use the Amazon Linux AMI for example).
Then copy the contents of the /opt/coldfusion10/config/wsconfig/1/ folder over to the new linux servers.
In that directory edit the workers.properties file and change the line that says
worker.cfusion.host=localhost
To something like this:
worker.cfusion.host=ip.of.your.cf.server
Make sure the firewalls allow traffic to the port specified in this file from the web servers.
Next copy the /etc/httpd/conf/mod_jk.conf file from the CF server on to the web server, and add that to you httpd.conf (eg add Include mod_jk.conf, or put the file in a conf.d folder).
I think all that should work -- I haven't tested it. For security you might want to make sure you have setup a connector shared secret, see the CF10 Lockdown guide for instructions on setting that up.
Pete Freitag
Foundeo Inc.
ColdFusion Consulting & Products (FuseGuard, HackMyCF)
Votes
Translate
Translate
Report
Report
LATEST
Hi Peter,
Your answer is right, it did work, just the file location for mod_jk.conf is in /etc/apache2/mod_jk.conf.
Now I am going to the next step:
     - instead of 1 single CF instance I need 2 of them in a Cluster.
I did it work locally in my machine using static membershit configuration, because multicasting is not allowed in EC2.
If a follow you, I need to create the cluster and move the config to apache again, but in this case registering 2 more workers: the cluster as load balancer and the remote instance?
I am confuse about the main instance. It is a single point of failure? because I'll point the external apache web server to the IP of the cluster right?
Here is my workers file:
worker.list=CFCluster01
worker.CFCluster01.type=lb
worker.CFCluster01.balance_workers=cfusion,cfusion2
worker.CFCluster01.sticky_session=false
worker.cfusion.type=ajp13
worker.cfusion.host= MyIP1
worker.cfusion.port=8012
worker.cfusion.max_reuse_connections=250
worker.cfusion2.type=ajp13
worker.cfusion2.host= MyIP2
worker.cfusion2.port=8012
worker.cfusion2.max_reuse_connections=250
Votes
Translate
Translate
Report
Report
Resources
Documentation
