0 Replies Latest reply on Oct 29, 2007 7:59 AM by Z33
    Flash reading image file from webservice
      Hi guys,
      I want to download an image from a webservice. What would i potentially need in flash to get it working?
      I came up with the following strategy:
      Use a Bytearray to read in byte data of the image from the webservice. Each webservice call would return a different set of bytes, use these bytes to build the image in flash.
      I am not too sure about the specifics either, (i also need help on this). For example, I believe i need to use the ByteArray class and do I need to get a raw socket hooked up to the server or is just using the return data from the webservice and making another call sufficient?
      I am targeting AS3, however if anyones has done it in AS2 or can come up with it in AS2 then please post, it will help.
      Any help is much appreciated.
