6 Replies Latest reply on Apr 26, 2013 12:09 AM by Vamitul
    list images for a visible layers only
    BEGINNER_X Level 3
      I need images name for the layers visible is "true "only.
      i.e., document contains 10 images, but the conditions is (layers visible = true) then document images is 7.
      Trying Code:
      var myDoc = app.activeDocument
      var myGraphics = app.activeDocument.allGraphics
      alert("docMyGraphics " + myGraphics.length)
      var myLayer = app.activeDocument.layers.everyItem().getElements()
      for(k=0; k<myLayer.length; k++)
          if(myLayer[k].visible == true)
              for(i=0; i<myGraphics.length; i++)
                  alert(myGraphics[i].itemLink.name)
      Could anyone rewrite my code and give solution.
      Plz it is very urgent.....
      Beginner
        • 1. Re: list images for a visible layers only
          SureshRaji
          Hi
          Try this:
                      if(myGraphics[i].itemLayer == myLayer[k])         // Check the item is in visible layer
          • 2. Re: list images for a visible layers only
            BEGINNER_X Level 3
            Hi Selvaraj,
            Thanks for your quick response.....
            Its working fine. I have given points as a helpful answer to you.
            Beginner
            • 3. Re: list images for a visible layers only
              -hans- Level 4
              a layer's got a own property allGraphics
              • 4. Re: list images for a visible layers only
                Vamitul Level 4
                Hey Beginner, hey Suresh.
                http://jongware.mit.edu/idcs5/pc_Layer.html
                Each layer has it's own "allGraphics property, so a nicer way of doing is to use that:
                var doc = app.activeDocument;
                var myLinks = [];
                for (var i = 0; i < doc.layers.length; i++) {
                          if (doc.layers[i].visible) {
                                    myLinks.push("Layer "+i+"("+doc.layers[i].name+"):")
                                    var layerGraph = doc.layers[i].allGraphics;
                                    for (var j = 0; j < layerGraph.length; j++) {
                                              try {                                        //  not all graphics have a itemLink, for example the embedded ones
                                                        myLinks.push(layerGraph[j].itemLink.name);
                                              } catch (e) {
                                                        myLinks.push("Error: Graphic " + j + " on layer " + i + " might be embedded");
                alert (myLinks.join("\r"));
                • 5. Re: list images for a visible layers only
                  SureshRaji Level 2
                  Hi Vamitul
                  Thankyou for showing me the easiest way.
                  • 6. Re: list images for a visible layers only
                    Vamitul Level 4
                    one caveat: allGraphic, no matter weather it's on layer or doc (and as a matter of fact every property that starts with "all" - allParagraphStyles, allPageItems etc etc) returns a array, not a collection, so you can't use all the cool stuff (like everyItem) on it.
                    Marc has some excelent stuff here:
                    http://www.indiscripts.com/post/2010/07/on-everyitem-part-2
