1. Re: My Fonts change when opening an InDesign CS4 file with InDesign CS6
Peter Spier Apr 26, 2013 3:24 AM (in response to Willem_Wouters)There is, indeed a conversion effect, but not really an error, when opeing files in newer versions. The text engines change form version to version and you can expect text to reflow. I'm surprised, though that the tracking has changed. Normally you don't see reflow when opeing a .indd file in the newer version until you touch the text frame in some way.
You might want to send the file through .idml (which will force all the text to recompose as a side effect when it is reopened). See Remove minor corruption by exporting
3. Re: My Fonts change when opening an InDesign CS4 file with InDesign CS6
Peter Spier Apr 26, 2013 5:00 AM (in response to Willem_Wouters)Waht does it look like in a PDF exported from CS6?
5. Re: My Fonts change when opening an InDesign CS4 file with InDesign CS6
Peter Spier Apr 26, 2013 6:42 AM (in response to Willem_Wouters)Are you using the same computer where the file was created? If not, perhaps you have a different version of the font installed on the new machine.
6. Re: My Fonts change when opening an InDesign CS4 file with InDesign CS6
Willem_Wouters Apr 26, 2013 6:50 AM (in response to Peter Spier)The designer who set the text is indeed on a different computer - she has Windows + InDesign CS4, I have Mac OSX 10.8.3 + InDesign CS6 (version 8.0.1) here. I will ask her to resend me her fonts. Thanks for you input, I'll keep you posted.
7. Re: My Fonts change when opening an InDesign CS4 file with InDesign CS6
Mike de Wolf May 7, 2014 3:24 AM (in response to Willem_Wouters)It's more than a year ago since this issue was reported, but at this time I'd had the same problem when opening a CS4 document in CS6/CC.
I was amazed that a header, placed in capitals, looked different in CS6/CC. But at last, after several tests, i've came to the conclusion that "forced" capitals behaving different than "real" capitals. In others words: when you forcing text to capitals the kerning would be different in CS6/CC. When you place text in real capitals (Shift + text) the kerning is the same as in both InDesign versions.
Text in CS4:
As you can see: in CS4 there's no difference between real capitals en forced capitals.
Below the results when opening the CS4 file in CS6/CC:
I'm not sure if there are still people struggling with this problem, but hopefully was is this helpful.
8. Re: My Fonts change when opening an InDesign CS4 file with InDesign CS6
David W. Goodrich May 7, 2014 8:14 AM (in response to Mike de Wolf)Thanks for reporting back on this. Peter Spier mentioned early on that recomposition could be a factor, a possibility you eliminated for the original CS4 samples by running them through *.inx and *.idml. Could it be that opening a CS4 file in CC does not force recomposition? Did you try forcing it? (The Keyboard shortcut for recompose all stories is Command-Option-/ [slash] or Ctrl-Alt-slash.) I also wonder whether you see the same effect for text with kerning set to Metrics rather than Optical (and presumably toggling between would force local recomposition).
I'll also add that as a Windows user I was initially confused by the appearance of a post-CS4 icon for ID in your CS4 sample, but then I remembered that may be a Mac quirk.
David
9. Re: My Fonts change when opening an InDesign CS4 file with InDesign CS6
Peter Spier May 7, 2014 8:52 AM (in response to David W. Goodrich)David W. Goodrich wrote:
In fact just opening a .indd in a newer version does not force a recompose. Touching the text will trigger it, though, and that can have some very unpleasant reflow implications in longer docs, with chapters running into overset, or starting on the wrong page and the unsuspecting user might not notice.
