7 Replies Latest reply on Mar 11, 2014 9:05 AM by resdesign
    Random numbers in a text
      Hi all,
      how can I get a Random Number in a Text by clicking a button?
      For example: I have an already animated object [a dice] as button and I have a Text object located on other part of the stage and where should appear the random number from 1 to 6.
      I have tried in CreationComplete and compositionReady, and in the Click option in the button, one of these two options:
      var ran_number=Math.floor(Math.random()*5;
      I have also tried in the dice image [button] within the symbol this [with one of the two previous codes]:
      And it doesn't work anyway. Right now I'm basically lost.
      Can anyone help me with this issue? [considering I'm a grown child-man, which means that help would be like: 1.- start your computer. 2.- open Edge. 3.- etc etc etc]  ;-)
      Many, many thanks in advance.
        • 1. Re: Random numbers in a text
          resdesign Adobe Community Professional & MVP
          This worked for me:
                    var ran_number = Math.floor((Math.random()*6)+1);
          Make sure your text is named text and not Text in the element panel.
          see file: https://www.box.com/s/h4t7sz8n7vhtpbhms747
          • 2. Re: Random numbers in a text
            yaotekatl52 Level 1
            Hi Resdesign!!!
            Thank you very, very, very much.
            I have tried your advice and it works!! I had been with this issue for almost three whole days, consulting different sources and trying a lot of diverse codes and combinations...
            I have to deliver this work [I'm completely new with HTML and Java] and since Flash is directing straight forward to the Forgotten Land I have to recicle myself.
            You just saved my neck.
            Thanks again and very kind regards.
            • 3. Re: Random numbers in a text
              My pleasure! Now go help someone else!
              • 4. Re: Random numbers in a text
                heathrowe Most Valuable Participant
                Nice one Marie
                • 5. Re: Random numbers in a text
                  Thank you Darrell!
                  • 6. Re: Random numbers in a text
                    This is really great!
                    Can you help me expand on this a bit please?
                    I am trying to create an 8 digit random number (that must be no less that 8 digits).
                        var ran_number = Math.floor((Math.random()*100000000)+1);
                    I figured that by simply using what you've supplied it'd just work but I've gotten 7 digit numbers as a result (every 10 clicks or so).
                    In the end, I'd like to have a person input a numerical password that either matches or doesn't match the random number.
                    Is there a way to create each integer one at a time and then when the user enters his password, have Edge check each integer one at a time?
                    I hope that makes sense!
                    Thank you!
                    • 7. Re: Random numbers in a text
                      I have 8 text fields with the names included in the array:
                      var numbers = ['onePlace','twoPlace','threePlace','fourPlace','fivePlace','sixPlace','sevenPlace','eigh tPlace'];
                      Then I have this for loop to randomize the numbers.
                          for(i=0;i<numbers.length; i++){
                                var ran_number = Math.floor((Math.random()*9));
                      sample here:
                      This below is not pretty but it works - it is for one text field.
                      for(i=0;i<9; i++){
                      var number1 = Math.floor((Math.random()*9));
                      var number2 = Math.floor((Math.random()*9));
                      var number3 = Math.floor((Math.random()*9));
                      var number4 = Math.floor((Math.random()*9));
                      var number5 = Math.floor((Math.random()*9));
                      var number6 = Math.floor((Math.random()*9));
                      var number7 = Math.floor((Math.random()*9));
                      var number8 = Math.floor((Math.random()*9));
                      sym.$('myNumber').html(number1+' ' +number2+' ' +number3+' ' +number4+' ' +number5+' ' +number6+' ' +number7+' ' +number8);
                      This would make it easy to compare the input with each number.
