3 Replies Latest reply on Apr 29, 2013 4:31 AM by aklimets
    Query Builder wildcard
    aslkit
      Can query builder use wildcard?
      My query is like following
      group.1_path=/var/statistics/pages/content/geometrixx
      orderby=@views
      orderby.index=true
      orderby.sort=desc
      The result will contain
      /var/statistics/pages/content/geometrixx/en/products/using-extjs-widgets/.stats/2013  (crxde,  html,  json)
      /var/statistics/pages/content/geometrixx/en/products/using-extjs-widgets/.stats/2013/01  (crxde,  html,  json)
      /var/statistics/pages/content/geometrixx/en/products/using-extjs-widgets/.stats/2013/01/21   (crxde,  html,  json)
      However, we just expect comparing the "day hit count" only.
      Should I apply wild card on this?
      I have tried to use wildcard but no result after search.
        • 1. Re: Query Builder wildcard
          aklimets Adobe Employee
          Can you clarify on what's wrong with the result?
          BTW, orderby.index=true workaround is not required anymore since CQ 5.3.
          • 2. Re: Query Builder wildcard
            aslkit Level 1
            /var/statistics/pages/content/geometrixx/en/products/using-extjs-widge ts/.stats/2013  (crxde,  html,  json)
            /var/statistics/pages/content/geometrixx/en/products/using-extjs-widge ts/.stats/2013/01  (crxde,  html,  json)
            /var/statistics/pages/content/geometrixx/en/products/using-extjs-widge ts/.stats/2013/01/21  (crxde,  html,  json)
            The result contains the statistic included year, month and day.
            However, in my case, I only interested for those hit count about day. What should be the query to do so?
            • 3. Re: Query Builder wildcard
              Use a node type or property constraint that only matches for those 2013/01/21 nodes. If the "view" property only exists on them, you can add this to your query:
              property=view
              property.operation=exists
