11 Replies Latest reply on Oct 29, 2007 2:40 PM by kglad
    a simple question
    DelinquentMe
      kk so the last one is a little wordy so how about this:
      this.ANIMopen._alpha = _global.tempAlpha;
      i put this code into frame 15 of an animated clip
      in the clip there are 3 key frames : 1, 15 and 30 with a motion tween between 1 and 15 and 15 and 30
      i used the above code piece to try and set the alpha level for the instance in frame 15
      if i put a trace(_global.tempAlpha) in the 15th frame of that clip IT DOES correctly return a 20
      any help on how to get that instance named "ANIMopen" in frame 15 to go clear when i run the MC would be most appreciated
