3 Replies Latest reply on Apr 27, 2013 12:44 PM by gkaiseril
    Auto date
    James A Hiltz CET Level 1
      I am having issues getting a auto date function to work in Adobe XI.
      any ideas?
        • 1. Re: Auto date
          Can you provide more information about what you're doing and what's going
          wrong?
          • 2. Re: Auto date
            Make sure you are not using the LiveCycle FormCalc script.
            For Acrobat:
            event.value = util.printd("d-mmm-yyyy", new Date());
            in the Custom Calculation script of  field with a format of "None" will insert the date each time a calculation is run.
            If you want the script to only run on a specific event you must select the specific event. Document open scripts are entered into the "Document Scripts" and you can either enter the code statements or create a function and call the function:
            function Init() {
            // function to run on opening of the PDF;
            // return the fromatted time string;
            // d-mmm-yyyy format for the date string
            var cFormat = "d-mmm-yyyy";
            // return the formatted string for now
            return util.printd(cFormat, new Date());
            // end Init function;
            // name for date field to be filled in;
            var cMyDateField = "DateField Name";
            // set the value of the date field by calling the Init function;
            this.getField(cMyDateField).value = Init();
            // end of document script;
            Make sure that JavaScript is enabled. Also check the JavaScript console for errors.
            • 3. Re: Auto date
