I think that I'd start here by taking all of the video
controls out of the onLoad handler, and only use that to retreive
the list, and push it into an array that is outside of this method.
It is also effecting 'scope' here, and the keyword 'this' is in
reference to the LoadVars Object return, so the use of it to target
the FLVPlayBack Component isn't going to work. Also 'length' is a
read only property of an array and not 'settable' (ie. to 1).
Additionally, 'videos' is defined as an array here, and not an
Object Listener, this needs to be a separate element.
So first thing, take all the video controls out, then use the
onLoad handler to set up the array outside, and to trigger a method
that you define to itereate through the array's playlist, using the
Component's event handlers.
