5 Replies Latest reply on Apr 28, 2013 6:58 PM by Jim_Simon
    Move all clips in sequence behind selected clip or paste?
    abUSER23 Level 1
      So if you are in the sequence editor and you need to move a clip, say insert some extra time or a new footage item.. is there a way to move all the clips in the sequence with out using shift select to select everything? Like if you hold SHIFT+DEL it will delete a section of a clip and then shuffle move all the clips behidn that point so there is no gap in the timeline.. is there a way to either Paste somthign in like this, or slect a clip and move it and all the other clips behind it in the sequence also move?
