1. Re: Slideshow transitions speeds and slide duration
Malcolm Brooks Apr 29, 2013 7:53 AM (in response to DerekDigital)Nice looking micro site. The slideshows are in sync for me? Im using Safari
2. Re: Slideshow transitions speeds and slide duration
DerekDigital Apr 29, 2013 9:00 AM (in response to Malcolm Brooks)Thanks for the compliment Malcolm.
On the face of it the slides do look in sync but for me there's almost a half second delay between the two shows.
In the previous version of the site the background image changed at exactly the same time as the text.
If you look closely there now appears to be a slight delay.
I'm aware that Adobe provided us with more controls over slideshow transitions, which was most welcome.
I just wondered if there were any guidelines anywhere on how to use them.
It may be a case that different bandwidths are causing this slight outage - but that's me speaking off the top of my head!
I'll muck around with the settings a bit more and see if I can achieve the same effect as the site once had.
3. Re: Slideshow transitions speeds and slide duration
Malcolm Brooks Apr 29, 2013 9:50 AM (in response to DerekDigital)I think you're being a bit picky It looks exactly the same to me
4. Re: Slideshow transitions speeds and slide duration
DerekDigital May 7, 2013 7:59 AM (in response to Malcolm Brooks)I guess I am being picky Malcolm.
However I've discovered that when the two slideshows are out wildly out-of-sync, which can happen, then a quick browser refresh resolves the problem.
I certainly didn't need to do that with this site when it was originally built in Adobe Muse 1.0 and updated in v3.x
Fingers-crossed the next version of Muse will iron out any slideshow bugs introduced in v4.x
5. Re: Slideshow transitions speeds and slide duration
lejeremiah Jul 2, 2014 8:56 AM (in response to DerekDigital)Hey neat micro-site there. I think I know what's the issue here..
The first time I visited the site, the two slideshows are indeed wildly out-of-sync. But when I decided to go back and view it again, they are at most .2s off sync.
I believe this is due to the time needed to load the larger slideshow (back images) vs the smaller slideshow (text).Therefore, during my first visit, the image slideshow took a while to load and begin, thus off-syncing the two.
I'm afraid I can't introduce any solution to this, as the download speed varies greatly from place to place.
Nonetheless, I think the site looks pretty good even when it's off-synced. -
6. Re: Slideshow transitions speeds and slide duration
DerekDigital Jul 3, 2014 5:14 AM (in response to lejeremiah)Hi. Thanks for the response and the feedback - both very much appreciated.
Since my original post we've had several updates of Muse and the slideshow timing issue seems to have resolved itself.
In addition I've changed the smaller slideshow to a Muse "Composition" widget to make the editing of text more productive.
This also appears to have eliminated many of the glitches I was experiencing a year ago.
