1 Reply Latest reply on Apr 29, 2013 10:39 AM by Sandeep333
    Enabling DVR in FMS4.5
    Sandeep333
      I have a livevent for which I want to enable DVR.  The event name is liveevent, but when I stream live event it does not show rewind button on player though event plays fine. I am using HDS and this is the URL provided to player http://servername/hds-live/livepkgr/_definst_/liveevent/livestream.f4m
      What  might be the problem?
      My manifest files look like below
      Manifest.xml
      <manifest xmlns="http://ns.adobe.com/f4m/2.0">
        <baseURL>http://servername/hds-live/livepkgr/_definst_/liveevent/</baseURL>
      <dvrInfo  windowDuration="-1"/>
        <media href="livestream.f4m" bitrate="650"/>
      </manifest>
      Events.xml
      <Event>
          <EventID>liveevent</EventID>
          <Recording>
              <FragmentDuration>4000</FragmentDuration>
              <SegmentDuration>10000</SegmentDuration>
      </Recording>
      </Event>
      Application.xml
      <Application>
           <HDS>
              <Recording>
                  <SegmentDuration>16000</SegmentDuration>
                  <DiskManagementDuration>4.5</DiskManagementDuration>
              </Recording>
          </HDS>
          <StreamManager>
              <Live>
                  <!-- When enabled, the server will assume that incoming live streams have -->
                  <!-- timestamps that are based on an absolute clock, such as a SMPTE time -->
                  <!-- signal contained within the encoder's input source.                  -->
                  <!-- Default is false.                                                    -->
                  <AssumeAbsoluteTime>true</AssumeAbsoluteTime>
                  <!-- Allow take over so that encoders that go down (for some reason) and  -->
                  <!-- and come back up can immediately republish.                          -->
                  <PublishTimeout>0</PublishTimeout>
                  <!-- When enabled along with AssumeAbsoluteTime, the server will          -->
                  <!-- assume that incoming live streams will always maintain the           -->
                  <!-- timestamps based on an absolute clock across server and stream       -->
                  <!-- restarts.                                                            -->
                  <!-- Default is true.                                                     -->
                  <AdjustForRecordingRollover>false</AdjustForRecordingRollover>
              </Live>
          </StreamManager>
      </Application>
