1. Re: ISO file over 25 GB - Encore says it 21 GB????
John T Smith Apr 29, 2013 3:29 PM (in response to EdwurdAdam)>I have set up a DVD... I made an Blu-Ray ISO file
I am confused... which is it, DVD or BluRay?
I know that a DVD project will allow you to add computer files in the ROM content box... does BluRay have the same option?
2. Re: ISO file over 25 GB - Encore says it 21 GB????
EdwurdAdam Apr 29, 2013 3:43 PM (in response to John T Smith)Hi John,
I am making a Blu-Ray Disc, not a DVD, sorry.
3. Re: ISO file over 25 GB - Encore says it 21 GB????
bigmanfontu Apr 30, 2013 11:38 AM (in response to EdwurdAdam)What do your transcoding settings look like?
If you go to File > Project Settings > then click on the "Default Transcoding Settings" button. What is your maximum audio/video bit rate setting set too?
Just for troubleshooting sake, can you change it to a lower setting to see if the size of the ISO decreases in size?
4. Re: ISO file over 25 GB - Encore says it 21 GB????
EdwurdAdam Apr 30, 2013 2:33 PM (in response to bigmanfontu)Hi,
I just did what you said it the" Maximum Audio/Video Bit Rate" setting is set to 15. That is the lowest setting.
5. Re: ISO file over 25 GB - Encore says it 21 GB????
Stan Jones Apr 30, 2013 3:05 PM (in response to EdwurdAdam)The default transcode setting would only effect motion menus and the like. You can set timeline asset transcodes above that limit. It is a very tempting alternative, but I do not believe it is the source of the "content is really bigger than Encore predicts."
