1 Reply Latest reply on Nov 5, 2007 7:06 PM by dnii
    DataGrid: dataTipField doesn't seem to work on columns with itemRenderer
    dnii
      I have a heavily custom styled DataGrid and have a need to show tool tips for data in the columns, especially for columns that use images (symbols).
      The tool tips show up nicely (set dataTipField and showDataTips) except for columns that use an itemRenderer which in my case, are quite a few columns...
      Help! Any idea how to get around this problem?
        • 1. Re: DataGrid: dataTipField doesn't seem to work on columns with itemRenderer
          dnii Level 1
          Found a solution if your itemRenderer is anActionScript subclass:
          You will have to set the itemRenderer's toolTip yourself.
          1. Still set the dataTipField to the dataField that holds your tool tips.
          2. Overwrite the set data method like this:
          override public function set data(value:Object):void
          super.data = value;
          // Assign the dataTipField value to the toolTip
          this.toolTip = data[this.styleName.dataTipField];
          This seems to work fine for me.
