7 Replies Latest reply on May 2, 2013 3:16 AM by Petfactory
    UI base class
    Petfactory
      Hi!
      I want to create a ui "base class" that I can reuse. I have done a test that works when I launch it from ESTK but when launched from within Illustrator the window flashes then disappears. The idea was to create a function that returns the window and a group to which I can add more controls to from the class that "instantiates the base class".
      Below is a simplified example of the base class.
      #target Illustrator
      #targetengine main
      function UIBase(aTitle)
          var win = new Window ("palette", aTitle);
          win.margins = 0;
          var banner = win.add ("group",[0,0,200,60]);
          banner.graphics.backgroundColor = banner.graphics.newBrush (banner.graphics.BrushType.SOLID_COLOR, [0.2, 0.2, 0.2]);
          var body = win.add ("group");
          body.margins = 10;
          return {"win":win, "body":body};
      The script that uses the base class looks like this.
      #include UIBase.jsx
      winObj = new UIBase("Hello World!");
      win = winObj["win"];
      body = winObj["body"];
      var btn = body.add("button", undefined, "Button!");
      win.show();
      It would be super handy to do something like this so that I dont have to rewrite code for the basic ui. Like I said it works from the ESTK but not from within illustrator. Does anyone have any ideas why this is not working? I am also interested if you have some examples of another way implementing a "ui base class" that can be extended.
      Best Regards,
      Johan
        • 2. Re: UI base class
          Petfactory Level 1
          Hi!
          That pdf is a really good resource, but I did not find exactly was I was looking for. After some additional googeling I found the $.evalFile() command. I used that command to "import" the base file instead of #include and it seems to work fine.
          BR,
          Johan
          • 3. Re: UI base class
            milligramme Level 3
            Hi. that code doesnt work for me.
            1. remove #target and #targetengine line from UIBase.jsx
            2. add only #target Illustrator to execute.jsx
            3. change to #targetengine session or something, NOT main
            4. or try with 'dialog' instead of 'palette'
            5. add #includepath /dirpath/to/UIBase.jsx to execute.jsx
            I tried this lists, and works fine both 'dialog' and 'palette'
            thank you.
            mg
            • 4. Re: UI base class
              Petfactory Level 1
              I tried what you suggested but I did not get the palette window to stay open. If I use  a "dialog" it works but I want to be able to have the window open while I work, and that is not possible with a window of the dialog type.
              The "base class" UIBase.jsx:
              The files that includes "the base class":
              #target Illustrator
              #include UIBase.jsx
              var runBtn = body.add ("button", undefined, "Button");
              win.show ();
              I changed the targetengine to session in the file that calls the "base class". I used just the #include since the file I wish to include is in the same folder. Like I said it works fine with a dialog type window, and it works from ESTK ( when the targetengine is set to main, I assume that I can not use a custom targetengine from ASTK ?)
              What am I missing to make this work with a window of the palette type ?
              Thank you,
              Johan
              • 5. Re: UI base class
                Muppet Mark Level 5
                #targetengine main will cause a palette to stay open…
                • 6. Re: UI base class
                  Petfactory Level 1
                  Hi Mark,
                  When using #targetengine main in a script with a palette window created form a single jsx file it works as expected, the palette stays open. But I am including a "base class" UI file which has some code that I wish to reuse across multiple scripts. When using the #targetengine main in this file the windows disappears a short moment after it becomes visible. I am using a mac by the way.
                  Any ideas?
                  Best Regards,
                  Johan
                  • 7. Re: UI base class
                    Petfactory Level 1
                    This is a strange behaviour. When I include a file useing the #include preprocessor the palette window flashes and disappears. If I remove the #include it works... hmmmm.
                    #target illustrator
                    #targetengine main
                    //#include INCLUDE.jsx
                    var win = new Window ("palette", "Palette");
                    win.show();
                    Anyone got an idea why this is ?
                    BR,
                    Johan
