9 Replies Latest reply on May 1, 2013 3:35 AM by Ann Bens
    Green screen Help
    alexdejesus Level 1
      I got a clip from Shutterstock of a stage curtain opening over a green screen. Originally downloaded as .mov file 1920x1080i. It was PAL so I changed frame rate to 29.97 progressive in AME converted it to H264. I want to composite a show I filmed, but am having a tough time with the jagged edges I can't get rid of. Does not look realistic at all. Not even a little bit.Greenscreen.jpgGreenscreen 2.jpg
      First of all, I need to change the color of the curtain to a dark blue. As you can see in my effect settings. I set similarity to 75%, but still have problems. 100% would distort the curtain color. I am not sure how to proceed. Should I change curtain color first, and then key out the green? WHich of the sliders will get rid of the jadded edge? Should I have converted the original file if it is 25 fps and my project is NTSC?
      I also added an antialias filter, but not sure it does anything.
      Should I try it in After Effects?
