4 Replies Latest reply on May 3, 2013 9:08 PM by STHLMscript
    Bring items in front of another
    STHLMscript Level 1
      The applescript dictionary for InDesign says:
      "bring to frontv : Brings the object to the front of its layer or in front of a particular item."
      But how do you write to bring the object in front of a particular item? The command only accept one parameter (the object that it brings to front).
        • 1. Re: Bring items in front of another
          Jump_Over Level 5
          this parameter is exactly what you need
          myObject.bringToFront(particularObject);
          Jarek
          • 2. Re: Bring items in front of another
            STHLMscript Level 1
            Thanks Jarek,
            you saved my day! Though I had to use the "do script"-command to make it work in Applescript:
            tell application "Adobe InDesign CS5"
                      set mySelectedPageItems to selection
                      set myObject to item 1 of mySelectedPageItems
                      set particularObject to item 4 of mySelectedPageItems
                      do script "arguments[0].bringToFront(arguments[1])" language javascript with arguments {myObject, particularObject}
            end tell
            I wasted so many hours yesterday trying to work it out in AS, but failed. Maybe someone know the right syntax in AS?
            • 3. Re: Bring items in front of another
              Jump_Over Level 5
              I would try:
                      tell myObject
                             bring to front of particularObject
                        end tell
              end tell
              however can not test it
              Jarek
              • 4. Re: Bring items in front of another
                STHLMscript Level 1
                Tried it - and it didnt work! In this case the script will place the "particularObject" on top of every other object. I've also tried:
                set myObject to bring to front of particularObject
                ...with the same result. It's irritating. But anyway, with your help I found a way around the problem
