2 Replies Latest reply on May 9, 2013 2:31 AM by sivaprasadreddys
    Workflow Process Implementation not found
    sivaprasadreddys Level 2
      Hello,
           I've created a workflow process in AEM 5.6.  When I initiate the workflow, the workflow is not completed and in the Inbox Console, I see 'process implementation is not found'.
      Here is the sample workflow process:
      package com.test.workflowtest;
      import org.apache.felix.scr.annotations.Component;
      import org.apache.felix.scr.annotations.Properties;
      import org.apache.felix.scr.annotations.Property;
      import org.apache.felix.scr.annotations.Service;
      import org.osgi.framework.Constants;
      import org.apache.felix.scr.annotations.Reference;
      import com.day.cq.workflow.WorkflowException;
      import com.day.cq.workflow.WorkflowSession;
      import com.day.cq.workflow.exec.WorkItem;
      import com.day.cq.workflow.exec.WorkflowData;
      import com.day.cq.workflow.exec.WorkflowProcess;
      import com.day.cq.workflow.metadata.MetaDataMap;
      import com.adobe.granite.workflow.WorkflowException;
      import com.adobe.granite.workflow.WorkflowSession;
      import com.adobe.granite.workflow.exec.WorkflowProcess;
      import com.adobe.granite.workflow.exec.WorkItem;
      import com.adobe.granite.workflow.metadata.MetaDataMap;
      import org.slf4j.Logger;
      import org.slf4j.LoggerFactory;
      import org.apache.sling.api.resource.ResourceResolverFactory;
      import org.apache.sling.api.resource.ResourceResolver;
      @Component
      @Service
      @Properties({
              @Property(name = Constants.SERVICE_DESCRIPTION, value = "Test Process."),
              @Property(name = Constants.SERVICE_VENDOR, value = "TEST"),
              @Property(name = "process.label", value = "Test WF Process")})
      public class Test implements WorkflowProcess{
         private static final Logger log = LoggerFactory.getLogger(Test.class);
                @Reference
                private ResourceResolverFactory resourceResolverFactory;
                public void execute(WorkItem item, WorkflowSession session, MetaDataMap args)
              throws WorkflowException {
              log.debug("======== Test Process ===========");
              ResourceResolver resolver = null;
              try{
                                    resolver = resourceResolverFactory.getAdministrativeResourceResolver(null);
              }catch(Exception e)
                  e.printStackTrace();
      Exception:
      02.05.2013 11:25:23.305 *ERROR* [JobHandler: /etc/workflow/instances/2013-05-02/model_79635435153979:/content/test1] com.adobe.granite.workflow.core.job.JobHandler Process implementation not found: com.test.workflowtest.Test com.adobe.granite.workflow.WorkflowException: Process implementation not found: com.test.workflowtest.Test
                at com.adobe.granite.workflow.core.job.HandlerBase.executeProcess(HandlerBase.java:221)
                at com.adobe.granite.workflow.core.job.JobHandler.process(JobHandler.java:139)
                at org.apache.sling.event.jobs.JobUtil$1.run(JobUtil.java:272)
                at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
                at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
                at java.lang.Thread.run(Unknown Source)
      02.05.2013 11:25:25.333 *ERROR* [JobHandler: /etc/workflow/instances/2013-05-02/model_79635435153979:/content/test1] com.adobe.granite.workflow.core.job.JobHandler Process implementation not found: com.test.workflowtest.Test com.adobe.granite.workflow.WorkflowException: Process implementation not found: com.test.workflowtest.Test
      02.05.2013 11:25:27.361 *ERROR* [JobHandler: /etc/workflow/instances/2013-05-02/model_79635435153979:/content/test1] com.adobe.granite.workflow.core.job.JobHandler Process implementation not found: com.test.workflowtest.Test com.adobe.granite.workflow.WorkflowException: Process implementation not found: com.test.workflowtest.Test
      02.05.2013 11:25:29.389 *ERROR* [JobHandler: /etc/workflow/instances/2013-05-02/model_79635435153979:/content/test1] com.adobe.granite.workflow.core.job.JobHandler Process implementation not found: com.test.workflowtest.Test com.adobe.granite.workflow.WorkflowException: Process implementation not found: com.test.workflowtest.Test
      Findings:  Gettting exception only when I use below code in the workflow process.
      @Reference
      Any help would be more helpful..
      Siva
