1. Re: Quality issues with inserted video file
Varun Kalra May 2, 2013 11:44 AM (in response to SaSchem)Hi there,
In which format are you publishing the output?
What is the resolution of your project and resolution of the inserted video.
Have you tried unchecking the compression options (edit > Preferences > swf size and quality > make it custom, uncheck advanced project compression and compress swf file).
also try at the time of publishing check 'force re publish all slides'.
2. Re: Quality issues with inserted video file
SaSchem May 3, 2013 12:59 AM (in response to Varun Kalra)Hello Varun,
thank you very much for your reply.
I tried unchecking the compression options, doesn’t help
I haven’t yet published the project, the problems occur already when playing the project in Captivate.
The project resolution is 1280x720.
The resolution of the .mov-file of the video is 1920x1080 (12000Kbps, if this information is any helpful…)
The resolution of the .wmv-file of the video is 1280x720 (3000Kbps…)
Maybe the problem occurs already during encoding, the .flv that is created by the Media Encoder doesn’t look that good anymore, I just played it separately (not in a Captivate project).
Are there any settings I could check for the Media Encoder?
Sabine
3. Re: Quality issues with inserted video file
rpope251 Feb 3, 2014 8:53 PM (in response to SaSchem)I think this has to do with video smoothing not working in Captivate. I have a similar problem with mp4's that are inside a project that is published to Flash from Captivate 7.
4. Re: Quality issues with inserted video file
SaSchem Feb 3, 2014 8:53 PM (in response to rpope251)Sehr geehrte Damen und Herren,
Vielen Dank für Ihre Nachricht.
Ich bin nicht mehr bei skill:form erreichbar.
Bei Fragen wenden Sie sich bitte an Herrn Dr. Kuhn t.kuhn@skillform.de oder an Frau Mohnke c.mohnke@skillform.de, vielen Dank.
Mit freundlichen Grüßen,
Sabine Schemske
