2 Replies Latest reply on May 8, 2013 12:03 AM by vinothr82
    Determine page item type from xmlelement
    s.vnesh Level 1
      I have a page item (text frame or text on path) that has been tagged (say tag named pp).
      I need to determine if it is a text frame or text path using the xmlelement.
      Can anyone guide how to do this?
      I tried the following:
      var items = doc.xmlElements[0].evaluateXPathExpression("//pp");
      var story = items[0].parent.parentStory;
      story.pageItems.item(0).allPageItems.item(0).constuctor.name // this should be textframe or textpath
      But could not succed.
      Kindly help!
        • 1. Re: Determine page item type from xmlelement
          absqua Level 4
          Try:
          $.writeln(items[0].xmlContent.textContainers[0].constructor.name);
          Jeff
          • 2. Re: Determine page item type from xmlelement
            vinothr82
            items[0].xmlContent.textContainers[0].constructor.name may not work in all cases.
            For instance, if you have simply tagged the text in a text frame or a text path then
            items[0].xmlContent would return Text object for which textContainers property is not available.
            You could try the following:
            var xmlElems = doc.xmlElements[0].evaluateXPathExpression("//pp");
            var parentTF = xmlElems[0].texts.item(0).parentTextFrames[0];
            if(parentTF instanceof TextFrame)
            $.write ("Text Frame");
            else if (parentTF instanceof TextPath)
            $.write ("Text Path");
