1 Reply Latest reply on May 3, 2013 8:19 AM by joe bloe premiere
    h.264 for film festival
    nickflix Level 1
      Hi. My film has been lucky enough to have been accepted into a film festival and the festival director would like an HD h.264 version for the screening. I have to send it so I made a 720p version because a 1080 version would be almost 8gigs and a 720 version would only be 1.5gb(he said 720 would be fine).  My question is, going under the h.264 in export, I chose HDTV 720p 24fps since that seemed to be the highest quality choice under the h.264s.My main question is, do you think this is the right one to choose? His email said as long as the data rate is under 15mbps, looking at it, it's data rate is 5972kbps, so I think I'm cool, although I'm now questioning whether this is actually too low. In the end, I'd just like to know if this was the right choice to make in terms of export. Sorry for the question, I'm just a little nervous because it's all on me for whether the film shows correctly at the festival.
        • 1. Re: h.264 for film festival
          joe bloe premiere Level 5
          Do you not have a delivery method for an 8GB 1080 file?
          If you do, I would send 1080 even if he says 720 is fine.
          He did not specify a file size limit, correct?
          His email said as long as the data rate is under 15mbps, looking at it, it's data rate is 5972kbps...
          I would max out the bitrate to the level he specified.
