1 Reply Latest reply on May 4, 2013 3:44 PM by Jump_Over
    Scaling clipped text frames
    frameexpert Level 4
      Hi, I have a text frame that is an anchored rectangle. The text frame is the same size as the rectangle and some of the text gets clipped. I want to scale the text frame 99% so that the text is not clipped. I want to change the scaling instead of the geometric bounds of the text frame to ensure that I don't get any overset text. I want to scale the text frame around its center point. There are a few things I don't understand about this:
      1) It looks like I can change the horizontalScale and verticalScale (or the absoluteHorizontalScale and absoluteVerticalScale) values, but when I query them after setting them to 99, they always return 100. I thought that they would return 99 so that I can see that they are already scaled, in case the script is run twice.
      2) I see also that there are scale and transform methods, but I am not sure if one of these is preferable.
      In any case, is there a way for me to test to see if a text frame (or any other object) has already been scaled? And if you can give me an overview of the best way to scale these text frames, I can look up the actual syntax in the object references. Thanks in advance for any help.
      Rick
        • 1. Re: Scaling clipped text frames
          Jump_Over Level 5
          Notice app.transformPreferences.whenScaling options.
          If you set it to WhenScalingOptions.ADJUST_SCALING_PERCENTAGE
          You can see current scale factor and you are able to redefine scaling back to 100%
          But be awared about side effects:
          i.e. scaled text pointSize property keeps original value
          Jarek
