3 Replies Latest reply on May 4, 2013 2:12 PM by Peter Spier
    InDesign Cs6 stopped working
      I always used InDesign (and the rest of the Adobe Creative Suite) without any problems. At one point I got an error message "Adobe InDesign has stopped working". I de-installed it and used the Adobe Cleaning tool to get clean the old info. I re-installed the latest version (CS6), but now it still starts with that same error message, I don't even get the chance to open a new document! I ran my antivirus (again), but no funny things going on. What to do??
        • 1. Re: InDesign Cs6 stopped working
          OS? Any other error message or indications of what went wrong? Are you running from an Administrator account? Do you use a font manager (name and version)?
          • 2. Re: InDesign Cs6 stopped working
            mae_tic Level 1
            Thanks for replying! But I already found my solution! After a few weeks of frustration and putting this message online I found out that it was the default printer that caused the error. Normally I use a printer from my university network as my default printer, but this caused the error since the computer is not always connected to that network. Now I put the Microsoft XPS Document Writer as default and everything works fine.
            I run the Adobe Creative Suite CS6 on Windows 7, my error log showed the following:
            Faulting application name: InDesign.exe, version:, time stamp: 0x4f72c3ee
            Faulting module name: AGM.dll, version:, time stamp: 0x4f3a0265
            Exception code: 0xc0000005
            Fault offset: 0x0024d0cd
            Faulting process id: 0x1508
            Faulting application start time: 0x01ce4905ac3f0ca2
            Faulting application path: C:\Program Files (x86)\Adobe\Adobe InDesign CS6\InDesign.exe
            Faulting module path: C:\Program Files (x86)\Adobe\Adobe InDesign CS6\AGM.dll
            Report Id: 211d7fdd-b4f9-11e2-bd34-e02a822ba99d
            • 3. Re: InDesign Cs6 stopped working
              The error log does show that you need to run the 8.0.1 update, though.  Glad you figured out it was the printer.
