Expand my Community achievements bar.
Java adapter example not compiling
Avatar
Level 1
Hi folks,
Can anyone please let me know why I get the error : "1046:
Type was not found or was not a compile-time constant: Contact"
on this line :
public var contact:Contact; in my Flex 2 app example which I
am following at
http://livedocs.macromedia.com/flex/2/docs/wwhelp/wwhimpl/common/html/wwhelp.htm?context=LiveDocs_Pa...
I have followed the tut so far down to the letter, but still
no joy.
I have the following setup:
1) flex 2 data services setup at :
2) copied the structure as required for Contact.as - this
file is in the folder
C:\fds2\jrun4\servers\default\samples\DSLessons\samples\contact\Contact.as
which as far as I can tell is correct. The contents of contact.as
is straight from Adobe :
// Copyright (C) 2003-2006 Adobe Macromedia Software LLC and
its licensors.
// All Rights Reserved.
// The following is Sample Code and is subject to all
restrictions on such code
// as contained in the End User License Agreement
accompanying this product.
// If you have received this file from a source other than
Adobe,
// then your use, modification, or distribution of it
requires
// the prior written permission of Adobe.
package samples.contact
[Managed]
[RemoteClass(alias="samples.contact.Contact")]
public class Contact
public var contactId:int;
public var firstName:String = "";
public var lastName:String = "";
public var address:String = "";
public var city:String = "";
public var state:String = "";
public var zip:String = "";
public var phone:String = "";
the mxml is :
<?xml version="1.0" ?>
<mx:Application xmlns:mx="
http://www.adobe.com/2006/mxml">
<mx:Script>
<![CDATA[
import mx.data.DataService;
import mx.collections.ArrayCollection;
import samples.contact.Contact;
public var ds:DataService;
[Bindable]
public var contacts:ArrayCollection;
</mx:Script>
<mx:DataGrid id="dg" editable="true">
<mx:columns>
<mx:DataGridColumn dataField="contactId" headerText="Id"
editable="false"/>
<mx:DataGridColumn dataField="firstName"
headerText="First Name"/>
<mx:DataGridColumn dataField="lastName" headerText="Last
Name"/>
</mx:columns>
</mx:DataGrid>
</mx:Application>
as you can see, I have not even completed it yet !!!!
any help would be appreciated.
Smak
Avatar
Level 1
In which directory is your mxml file? It should be in
C:\fds2\jrun4\servers\default\samples\DSLessons.
The import samples.contact.Contact tells the compiler to look
for a directory structure samples\contact, then the class
Contact.as. This dir structure has to be under relative to the mxml
file.
-Jorge
Avatar
Level 1
BTW, a note was added by the Adobe doc guys:
mpeterson said on Jul 5, 2006 at 1:19 PM :
The "contact" sample application used in this tutorial IS
NOT included in the Flex Data Services samples web application. The
required files are available in the following zip file, which you
can unzip into the samples (root directory) of the samples web
application:
http://www.adobe.com/go/flex2_contact_app_zip
After unzipping the file, copy the following destination
definition after the last destination in the
samples/WEB-INF/flex/data-management-config.xml file:
<destination id="contact">
<adapter ref="java-dao" />
<properties>
<source>samples.contact.ContactAssembler</source>
<scope>application</scope>
<metadata>
<identity property="contactId"/>
</metadata>
<network>
<session-timeout>20</session-timeout>
<paging enabled="false" pageSize="10" />
<throttle-inbound policy="ERROR" max-frequency="500"/>
<throttle-outbound policy="REPLACE"
</network>
<server>
<fill-method>
<name>loadContacts</name>
</fill-method>
<fill-method>
<params>java.lang.String</params>
</fill-method>
<sync-method>
<name>syncContacts</name>
</sync-method>
</server>
</properties>
</destination>
- Mike Peterson
Adobe Flex documentation team
Avatar
Level 1
Jorge,
thanks for the quick reply, it is ok now I think.
Regards
Smak
Avatar
Former Community Member
Jorge,
Regards
Smak
