6 Replies Latest reply on May 6, 2013 6:39 PM by dlszung
    Writing Keywords to file
    dlszung
      Are catalog categories and sub categories written to photo file or just key words?   When looking at a catalogue hierarcy how do I know what is a key word and not a category or sub category?
        • 1. Re: Writing Keywords to file
          andaleebfatima1 Adobe Employee
          Catalog categories? Please explain what are these?
          If you mean tag categories then no, if you have applied a tag "Tim" to a file which is under "Family" category in tag panel, writing metadata to file will just write "Tim" in the image's IPTC metadata.
          Andaleeb
          • 2. Re: Writing Keywords to file
            dj_paige Level 10
            By default, none of these are written to the photos. Keywords are not written to the files either, by default.
            I believe that if you choose to use the command File->Write Tags, then all of these are written to the files. Why don't you try it yourself and find out?
            • 3. Re: Writing Keywords to file
              dlszung Level 1
              Using PSE 7.   In organizer can create create new categories, sub categories, and keyword tags.  But when I look at my hierarchy created over a number of years, how can I tell which are the keyword tags and can be written to the photo file?
              I've come to the conclusion that I should only use multiple keyword tags and not PSE Categories since cannot be written to the file (securely preserved).
              • 4. Re: Writing Keywords to file
                They can be written o metadata. You can drag drop a keyword tag category on media and write to its metadata using File > Save Metadata to File. There is no difference between a tag and its category when it comes to saving in metadata.
                Andaleeb
                • 5. Re: Writing Keywords to file
                  dj_paige Level 10
                  What evidence leads you to this conclusion?
                  • 6. Re: Writing Keywords to file
                    dlszung Level 1
                    After I realized that the organizer information is independent of the photo file (unless written), I wrote the keywords to the photo files and then used an EXIF viewer to view the keywords. I found some the organizer entries were not written to the file.  For example under Event I created Christmas and under Christmas created Christmas 2012.  Christmas 2012 was written to the photo file but Event and Christmas were not.   The problem is that I have to look at various photos to figure out what is written and what is not.  I have not been able to find a way to examine the hierarchy itself and see if an entry is a keyword.   I may not need Christmas but want to make sure information I need will be written to the file.
