2 Replies Latest reply on May 6, 2013 4:18 AM by FlexAce
    BindTriggerAction To A Symbol Instance?
    FlexAce Level 1
      I have a symbol (digit) that has it's own timeline
      I can dynamicaly put a stop on it's timeline like this in compositionReady
           Symbol.bindTriggerAction( compId, "digit", "Default Timeline", 1500, function(sym, e) {
                sym.stop();
      But I would like to just put the stop on one instance of the symbol on the stage
      This does not work
           Symbol.bindTriggerAction( compId, "InstanceNameHere", "Default Timeline", 1500, function(sym, e) {
                sym.stop();
      Any ideas if it is possible?
      And is it possible to dynamicaly remove/undo a bindTriggerAction?
        • 1. Re: BindTriggerAction To A Symbol Instance?
          Zaxist Level 4
          this "digit" is symbol or its a div ?
          and can you explain more ? it's not clear for me, if you can put your project here it would be better to help
          • 2. Re: BindTriggerAction To A Symbol Instance?
            FlexAce Level 1
            The digit is a symbol
            But I have multiple instances of that on my stage
            And I want to be able to add & remove a stop dynamically to only one instance
            project here
            http://awesomedigital.com/Numbers.zip
            Background-----------------------
            All of the digits make number that will change several times from an external call
            I want each of the digits to individually scroll to the new number on each change
            Ideally if there were a playToAndStop command I would love that
            But since there is not, my hack idea #422 is to
                      Stick a stop on the digit timeline (instance) and the play or play in reverse
                      Then remove the stop since it will be a differnt number to stop at next time
