3 Replies Latest reply on May 6, 2013 6:25 PM by Ushan Boyd
    Update hidden edit fields with a different value
    Ushan Boyd Level 1
      I am using a couple of web app fields to style other web app edit fields hidden or revealed.
      eg class="{tag_hideReveal 1}" will output class="hide" or class="reveal".
      When the web app is created the hideReveal values were set. I am trying to update the values in hidden fields using the edit page.
      However they always return the current value of the field, even if I physically write the opposite into the edit page code. I don't want this value to be set be customers, it must be hidden.
      How can I make these swap? Will jquery or javascript do it? Basically if one is reveal, I will want it to be hide, and vice versa.
      Edit page code
      __________________________________________________________________________________________ ____________________
      <div class="{tag_hideReveal 1}">
                   <label>Do you, the host, agree to the Term and Conditions and wish to make an offer to the visitor?</label>
                      <input type="checkbox" name="CAT_Custom_255715" id="CAT_Custom_255715_0" value="Yes" />Yes</div>
      <input type="hidden" name="CAT_Custom_257330" id="CAT_Custom_257330" class="hideReveal" value="hide" /><!-- was reveal, now I want it be hide -->
      <div class="{tag_hideReveal 2}"><label>Do you, the visitor, agree to the Terms and Conditions and accept the offer from the host?</label>
                      <input type="checkbox" name="CAT_Custom_255716" id="CAT_Custom_255716_0" value="Yes" />Yes</div>
      <input type="hidden" name="CAT_Custom_257331" id="CAT_Custom_257331" class="hideReveal" value="reveal" /><!-- was hide, now I want it be reveal -->
      Outputted code
      <div class="reveal">
      <input type="hidden" name="CAT_Custom_257330" id="CAT_Custom_257330" class="hideReveal" value="reveal" /><!-- was reveal, now I want it be hide -->
      <div class="hide"><label>Do you, the visitor, agree to the Terms and Conditions and accept the offer from the host?</label>
      <input type="hidden" name="CAT_Custom_257331" id="CAT_Custom_257331" class="hideReveal" value="hide" /><!-- was hide, now I want it be reveal -->
      Thanks!!
        • 1. Re: Update hidden edit fields with a different value
          thetrickster888 Level 4
          I'm just a little confused.  You are using these tags on the EDIT item layout for the web app? But you also want to reveal/hide some content based on their selection while on the edit layout view?
          Why are you using two {tag_hideReveal} tags (ie- {tag_hideReveal 1} and {tag_hideReveal 2}?  If you intend for it to be one or the other, you should use one tag {tag_hideReveal} and the value will be either "hide" or reveal". So then your code could be:
          <div class="{tag_hideReveal}">
          <input type="hidden" name="CAT_Custom_257330" id="CAT_Custom_257330" class="hideReveal" value="{tag_hideReveal}" /><!-- was reveal, now I want it be hide -->
          </div>
          And use CSS to hide .hide and you can do nothing with the .reveal class:
          .hide { display: none; }
          This way that DIV will be shown when hideReveal is set to reveal and be hidden when it's set to hide.
          I might be missing something from your explanation. Let me know if I am getting the gist.
          • 2. Re: Update hidden edit fields with a different value
            Ushan Boyd Level 1
            I know, it is a bit confusing. The reason being is that we have 2 customers using the smae edit form. Therefore, when one customer has editied it, I want the fields to update and be ready for th secod customer to use.
            Correct, .hide is display: none, and .reveal has no CSS and so is shown.
            The essential info is how to change the existing value of {tag_hideReveal} to the other value, in a hidden input. When the page loads, the value of the input is updated to the current value, regardless of what values I enter in the Edit code.
            I think it must be javascript.
            Anyway, thanks for looking!
            • 3. Re: Update hidden edit fields with a different value
              Ushan Boyd Level 1
              I added this to the head - it seems to work.
              Thank you!!
                   <script src="//ajax.googleapis.com/ajax/libs/jquery/2.0.0/jquery.min.js"></script>
              $(document).ready(function()
                                  $("#CAT_Custom_257330").val("hide");
                                  $("#CAT_Custom_257331").val("reveal");
              </script>
