1 Reply Latest reply on May 7, 2013 8:33 AM by Steve Sommers
    How to redirect to the same page ?
    gokul1242 Level 1
      i am using the following code to open a file on a cfm page ie.,when user clicking on a hyperlink it opens the cfm page and displays the pop up to save the file
      <cfif isdefined("url.isemailPopUP") and trim(url.isemailPopUP) eq "Y">
      <cfif isdefined("url.fileName")>
      <cfif #find(url.fileName,#fileWithThePath#,1)#>
      <cfheader name="Content-Disposition" value="attachment; filename=#url.fileName#">
      <cfcontent type="text/plain" file="#fileWithThePath#">
      but after the file has been downloaded .it does not displays the contents of the page or  redirects to the same page ....
      i have used cflocation. but it does not help....
        • 1. Re: How to redirect to the same page ?
          Steve Sommers Level 4
          You can't. Downloaded files do not do html or script processing, they only download the file. In some cases you can use the "target" parameter to spawn a child window when the user clicks the link for the download, but depending on the browser this will work perfectly or come across as bulky because a stray empty window will be left behind.
