5 Replies Latest reply on May 8, 2013 3:33 AM by csm_phil
    Looping over all xml elements
    SimonLinden
      How do I loop over all the tagged xml elements in a story? I've created a reference to the xml elements of the story I want like this:
      var xmlStory = myDoc.xmlElements[0].xmlElements[0];
      In this structure I have elements <v>10</v> that I want to change to <v id="10">10</v>. I'd like to do this in InDesign scripting and not with XSL upon export because of the workflow I'm planning. I know I can loop over the children in the structure like this:
      for(var i=0;i<xmlStory.xmlElements.length;i++){
                          if(xmlStory.xmlElements[i].markupTag.name == "v"){
                                    xmlStory.xmlElements[i].xmlAttributes.add("id", xmlStory.xmlElements[i].contents);
      This works fine for just the first level, but I want to find every element with the markup tag "<v>". These tags can appear at any level in the structure. How do I make sure all of them are included and not just the first child elements of the story element?
        • 1. Re: Looping over all xml elements
          csm_phil Level 4
          Hi SimonLinden,
          Please try the below JS code its works only CS5.5.
          #target InDesign;
          #include /Program Files (x86)/Adobe/Adobe InDesign CS5.5/Scripts/XML Rules/glue code.jsx// change the script path in your InDesign version CS4 or CS5
          //____________________ XML RULE SET
          var myRuleSet = new Array (new margintag);
          with(myDoc){
              var elements = xmlElements;
              __processRuleSet(elements.item(0), myRuleSet);
          function margintag(){
              this.name = margintag;
              this.xpath = "//v";
              this.apply = function(myElement, myRuleProcessor){
                  with(myElement){
                      try{
                          myElement.xmlAttributes.add("id", myElement.xmlContent.contents);
                          }catch(e){}
                  return true;
          thx,
          csm_phil
          • 2. Re: Looping over all xml elements
            Cenchen Level 2
            Try this,
            #target InDesign;
            var doc = app.activeDocument;
            var xmlTag = doc.xmlElements[0];
            var vTag = xmlTag.evaluateXPathExpression("//v")
            for(var i=0;i<vTag.length;i++)
                try
                    vTag[i].xmlAttributes.add("id",  vTag[i].xmlContent.contents)
                catch(e){}
            • 3. Re: Looping over all xml elements
              SimonLinden Level 1
              Thanks! This works perfectly. Didn't know about XPathExpressions but it seems to be just what I needed.
              • 4. Re: Looping over all xml elements
                SimonLinden Level 1
                Thanks for the suggestion cms_phil. I'm using CS6 so I couldn't get this code to work but I could do it with Cenchens suggestion.
                • 5. Re: Looping over all xml elements
                  csm_phil Level 4
                  Hi SimonLinden,
                  My code its working perfectly only CS5.5. Becuase I include the path for CS5.5 version folder path. You just change the below line.
                  You just change the below line and try again .
                  #include /Program Files (x86)/Adobe/Adobe InDesign CS6/Scripts/XML Rules/glue code.jsx// change the script path in your InDesign version CS4 or CS5
                  thx,
                  csm_phil
