1 Reply Latest reply on May 9, 2013 11:35 PM by Sham HC
    Issue in implementing Dynamic participant chooser process Step
    nephelem
      I am facing issue in implementing Participant chooser process Step.
      I want to create dynamic Participant chooser process Step, I have implemented 'ParticipantStepChooser' class and overwrote 'getParticipant' method. But this process did not appear in Dynamic participant chooser dropdown in CQ5.6 environment.
      I deployed same code in CQ5.5 and process appeared in Dynamic participant chooser dropdown.
      This is the sample code which I have used:
      @Component(immediate = true, metatype = true, label = "DMP Config Service123")
      @Service
      @Properties({
              @Property(name = Constants.SERVICE_DESCRIPTION, value = "A sample implementation of a dynamic participant chooser.", propertyPrivate=true),
              @Property(name = Constants.SERVICE_VENDOR, value = "Adobe", propertyPrivate=true),
              @Property(name = ParticipantStepChooser.SERVICE_PROPERTY_LABEL, value = "******** Hello ********", propertyPrivate=true),
              @Property(name = "immediate" , value = "true", propertyPrivate=true)
      public class MyDynamicParticipant implements ParticipantStepChooser {
          private static final String TYPE_JCR_PATH = "JCR_PATH";
          @Activate
      void activate(ComponentContext context) {
        LoggerUtil.infoLog(this.getClass(), " ");
          public String getParticipant(WorkItem workItem, WorkflowSession workflowSession, MetaDataMap args) throws WorkflowException {
        LoggerUtil.infoLog(this.getClass(), "inside getParticipant method{} ");
              WorkflowData workflowData = workItem.getWorkflowData();
              if (workflowData.getPayloadType().equals(TYPE_JCR_PATH)) {
      String path = workflowData.getPayload().toString();
      String pathFromArgument = args.get("PROCESS_ARGS", String.class);
      if (pathFromArgument != null && path.startsWith(pathFromArgument)) {
      return "admin";
              return "administrators";
        • 1. Re: Issue in implementing Dynamic participant chooser process Step
          Sham HC Level 7
          Make sure to change your imports in 5.6 to use granite api. Please change from [1] to [2].
          [1]
          import com.day.cq.workflow.WorkflowException;
          import com.day.cq.workflow.WorkflowSession;
          import com.day.cq.workflow.exec.ParticipantStepChooser;
          import com.day.cq.workflow.exec.WorkItem;
          import com.day.cq.workflow.exec.WorkflowData;
          import com.day.cq.workflow.metadata.MetaDataMap;
          [2]
          import com.adobe.granite.workflow.WorkflowException;
          import com.adobe.granite.workflow.WorkflowSession;
          import com.adobe.granite.workflow.exec.ParticipantStepChooser;
          import com.adobe.granite.workflow.exec.WorkItem;
          import com.adobe.granite.workflow.metadata.MetaDataMap;
