1 Reply Latest reply on May 9, 2013 6:42 PM by CopyPixels
    drag three or more sprites together
    anjemalo Level 1
      Hello:
      Please, can you tell me how to drag three or more sprites together it does not care with sprite you drag?
      have you any sample?
      many thanks to all
        • 1. Re: drag three or more sprites together
          CopyPixels
          The simple answer is to keep a list of the sprites and to use the "call()" handler to tell the group to do something.
          The actual implementation can take many forms. The approach I would use requires several scripts, but that is too complicated to explain. So, I took the code that I posted for you that lets you drag one sprite horizontally or vertically and added some code from a Radio Button script that does grouping, and created a behavior that I call "Collective Linear Drag".
          The behavior works by assigning a group name to each set of sprites that you want to move together. You can have more than one group on a screen at one time.
          The behavior is a little different in that it uses static properties and handlers. All that means is that some properties remember their values after the program is stopped - inside the IDE - and some handlers are accessed through the script member.
          Here is all you need to know to use the behavior:
          Use a prepareMove handler to clear the behavior's memory.
          on prepareMovie
            script("Collective Linear Drag").clear()
          end
          There is a handler that returns the last sprite click for all the current  groups.
          ie  put script("Collective Linear Drag").getLastClicked()
          That's about it. Just paste the code below into a Behavior script and attach it to several sprites with the same group name, and drag.
          -- Collective Linear Drag
          property  sp  -- this sprite
          property  pDirection  -- the direction to constain dragging,  #Horizontal, #Vertical
          property  pStartLoc  --  sprite location upon mouseDown
          property  pMouseStart  -- mouse location upon mouseDown
          property  pMoving  -- flag for enterFrame. True/False
          property  pGroupName  -- name of the group this sprite is part of
          -- Private Static Property
          property  pRadioGroups  -- property list of radio button group names and associated data
          On GetPropertyDescriptionList me
            Props = [:]
            Props[#pDirection] = [#default:#Horizontal, #format:#symbol, #Range:[#Horizontal, #Vertical], #comment:"Pick direction to drag"]
            Props[#pGroupName] = [#default:#Group01, #format:#symbol,  #comment:"Group Name."]
            return Props
          end GetPropertyDescriptionList
          on beginSprite me
            sp = sprite(me.spriteNum)
            if me.script.pRadioGroups[pGroupName].voidP then  -- need to add a new group name to pRadioGroups
              me.script.pRadioGroups[pGroupName] = [#Sprites:[], #LastClicked:void]
            end if
            me.script.pRadioGroups[pGroupName].Sprites.add(sp)  -- add this sprite to its group.
            pMoving = false
          end beginSprite
          on mouseDown me
            Sprites = me.script.pRadioGroups[pGroupName].Sprites  -- get list of sprites that this sprite belongs to.
            call(#startDrag, Sprites)  --  start dragging all the sprites in this group.
            me.script.pRadioGroups[pGroupName].LastClicked = sp  -- set this sprite as the last one clicked for its group
          end mouseDown
          on startDrag me
            pStartLoc = sp.loc
            pMouseStart = _mouse.mouseLoc
            pMoving = true
          end
          on mouseUp me
            call(#endDrag, Sprites)
          end
          on mouseUpoutside me
          end
          on endDrag me
            pMoving = false
          end
          on enterFrame me
            if not pMoving then exit
            deltaMouse = _mouse.mouseLoc - pMouseStart
            if pDirection = #Horizontal then
              sp.loc = pStartLoc + point(deltaMouse[1], 0)
            else
              sp.loc = pStartLoc + point(0, deltaMouse[2])
            end if
          end enterFrame
          ---------------  Grouping Code ------------------------------
          on new me,
            if  me.script.pRadioGroups.voidP then  -- no instance has been stored. Stored the one and only instance allowed.
              me.script.pRadioGroups = [:]  -- initialize property
            end if
            return me
          end new
          on clear me
          end
          on getLastClicked me  -- Returns a list of last buttons clicked/pressed for each group
            Clicked = [:]
            -- populate "Clicked" with a list of Group Name / Last clicked value pairs
            total = me.script.pRadioGroups.count
            repeat with Cnt = 1 to total
              Clicked[me.script.pRadioGroups.getPropAt(Cnt)] = me.script.pRadioGroups[Cnt].lastclicked
            end repeat
            return Clicked
          end getLastClicked
