0 Replies Latest reply on May 7, 2013 11:56 AM by Ford-ESB
    Web service soap call connection lost in rendered form generated by stichted fragments
    Ford-ESB Level 1
      Hi
      I have fragment which uses a webservice call to get data from database and the output is bind to fields on the fragment. these fragements are dynamically inserted in the insertion points and the fragments are stichted using assembler and the form is rendered and reader extensions are applied. when I click on the execute button of generated form the web service is not called because the connection is lost when the form is stichted and rendered.
      I used the fragment in a standalone form and reader extended that form and everything works fine, the web service is called and i get the data.
      can any body explain what is the problem with rendered form by stichthing the fragments, what needs to be done in case of stitched form?
      Mahesh
