10 Replies Latest reply on May 9, 2013 12:33 AM by SureshRaji
    Applescript to run javascript
    SureshRaji Level 2
      Hi all,
      I got error in this script. Could anyone help on this?
      tell application "Finder"
          activate
          set myApps to {"CS3", "CS4", "CS5"}
          set selectedApp to choose from list myApps with prompt "Choose Application:" with title "Launch Application"
          if the result is not false then
              set myApp to "Adobe InDesign " & selectedApp
              display dialog myApp
              set myFile to "Applications:" & myApp & ":Scripts:Scripts Panel:Sample.jsx"
              tell my application myApp
                  activate
                  run script file myFile   // error "Adobe InDesign CS4 got an error: A unknown token can’t go after this “)”." number -2740
              end tell
          end if
      end tell
      Regards
      Suresh
        • 1. Re: Applescript to run javascript
          Vamitul Level 4
          hey suresh..
          can't realy remember the last time i used applescript, but still here are my two cents:
          the javascript you are trying to run has a error somwhere in it. open it in estk and try a "Check Syntax" (form the edit menu)
          • 2. Re: Applescript to run javascript
            SureshRaji Level 2
            Hi Vamitul,
            Thanks for your quick response. I  checked the javascript in ESTK which shows no error.
            Even if I write a simple javascript (an alert message), applescript throw an error in the same line.
            Regards
            Suresh
            • 3. Re: Applescript to run javascript
              Vamitul Level 4
              ok...
                  activate
                       set myScript to POSIX path of myFile
                          activate
                          run script file myScript
                      end tell
                  end if
              end tell
              • 4. Re: Applescript to run javascript
                SureshRaji Level 2
                Hi Vamitul,
                Thanks for showing a different way to specify the path. It  throw an error in same line like this.
                run script file myScript // error "Adobe InDesign CS4 got an error: Can’t make some data into the expected type." number -1700 to item
                • 5. Re: Applescript to run javascript
                  Vamitul Level 4
                  aa.. it's do script, not run script. (just checking form the scripting guide) try:
                  do script alias myScript language javascript
                  • 6. Re: Applescript to run javascript
                    SureshRaji Level 2
                    Hi Vamitul,
                    It works fine when I edit the  script like this:
                        activate
                            --set myScript to POSIX path of myFile
                            tell application "Adobe InDesign CS4"
                                activate
                                do script alias myFile language javascript
                            end tell
                        end if
                    end tell
                    But how could I run to selected Application.
                    Regards
                    Suresh
                    • 7. Re: Applescript to run javascript
                      Muppet Mark Level 5
                      tell application myApp
                           activate
                      end tell
                      • 8. Re: Applescript to run javascript
                        SureshRaji Level 2
                        Hi Mark
                        Thanks for your reply. But it shows an error at this line
                        • 9. Re: Applescript to run javascript
                          -hans- Level 4
                          you're right. The script does not compile. I don't know the reason, perhaps Shane reads the thread and knows the answer. Macscripter.net may be a good point for posting this.
                          A workaround: Create the whole ID-Tellblock as string and do a vanilla run script command.
                              activate
                              set myApps to {"CS3", "CS4", "CS5.5"}
                              end if
                          end tell
                          set myString to "tell application " & "\"" & myApp & "\"" & return ¬
                              & "do script alias " & "\"" & myFile & "\"" & " language javascript" & return ¬
                              & "end tell"
                          run script myString
                          It runs here.
                          • 10. Re: Applescript to run javascript
                            SureshRaji Level 2
                            Hi hans
                            Thankyou. This works fine for me.
                            Thanks for everyone those who given me your suggestion.
                            Regards
                            Suresh
