2 Replies Latest reply on May 10, 2013 6:55 AM by cfnewbie12
    neo-cron.xml corruption - anybody knows what might be causing it?
    cfnewbie12
      Hi, I'm currently researching on why my company's ColdFusion application's neo-cron.xml file occasionally gets wiped out. This issue only happens to certain clients, so we're suspecting that it's an environmental issue and not something (at least not directly) caused by our application. We have recreated this issue occasionally on our internal testing/development environments, and both times it seems that the ColdFusion server is running low on resources (i.e. available memory is running low, processing is nearly reaching 100%, etc.). I have attempted to search elsewhere for possible causes for it, but had no luck. So I'm hoping the Adobe community has some insight into this problem. Thanks!
        • 1. Re: neo-cron.xml corruption - anybody knows what might be causing it?
          lukester85 Level 1
          Hello,
          I've had the neo-cron file corrupt itself a few times on one particular server.
          If you open the file is it just blank?
          For us, this was caused by a scheduled task that a customer was entering using CFSCHEDULE. I dont know what they did to break it, but break it they did, and continue to do so... I keep a backup and over-write when it happens.
          If you have the same type of issue i would be interested in the fix if you ever get one.
          Cheers
          Luke
          • 2. Re: neo-cron.xml corruption - anybody knows what might be causing it?
            cfnewbie12 Level 1
            Hi Luke,
            Can you provide some details on the server specification where the neo-cron file got corrupted (and yep, the file just got wiped out on our servers)? Also, what types of operation does this scheduled task involve? It would be helpful to gather that information so maybe some theory can be made about what type of scheduled task would corrupt the neo-cron file on the server. But the scheduled task of the customer doesn't always corrupt the file, right?
            Wai
