3 Replies Latest reply: Jan 27, 2014 8:59 AM by EnthusiastOfTheMind RSS
    Receiving INPUT TEXT, making Forms from scratch.
    Departure Community Member
      Hi All...
      I am trying to design a text form from scratch, How can i access to INPUT TEXT property of a text box ?
      I want to do this:
      -place a TEXT object on stage
      -have it RECEIVE INPUT TEXT (entered by user.)
      -Be able to access the INPUT TEXT in action panel so i can then use additional PHP stuff to send it as email or etc..
      I do not want to use those rectangular input box...i wanna create something totally ridicules lets say....(Somebody called this software EDGE and raised my expectations i guess )
        • 1. Re: Receiving INPUT TEXT, making Forms from scratch.
          EnthusiastOfTheMind Community Member
          Hi I'm fairly new to Edge, but I've managed to send data from input fields using the append/ajax method...
          //append input box to <div> in another symbol...
          //I have made a symbol called "contact_screen" on stage and this contains my input boxes (rectangle <div> called "InputEmail)
          var InputEmail = sym.getSymbol("contact_screen").$("InputEmail");
          //append the input field to your box. Note value is called to get the text content later
          $("<input type='text' value='' id='InputEmaili' size='80'>").appendTo(InputEmail);
          //set any css you want to the input field
          sym.getSymbol("contact_screen").$("#InputEmaili").css({"height":"29", "width":"492px", "font-family":"Annie Use Your Telescope, cursive", "font-size":"24px"});
          // do the same for your other input fields
          //then apply to a button click function
          var comp = sym.getComposition().getStage().getSymbol("contact_screen");
          //gets the values
          var name = comp.$("#InputNamei").attr("value");
          var email = comp.$("#InputEmaili").attr("value");
          var message = comp.$("#InputMessagei").attr("value");
          //sets the values as "data"
          var data = "name="+name+"&email="+email+"&message=" + message;
          $.ajax({
               type: "POST",
               url: "email/contact.php",
               //gets the data values
               data: data,
               success: function(phpReturnResult){
               alert('Thank you.'+'\r\n'+'Your message has been sent successfully!');
               //this resets the values after sent
               comp.$("#InputNamei").val("");
               comp.$("#InputEmaili").val("");
               comp.$("#InputMessagei").val("Your message has been sent.");
               sym.$("feedbackTxt").text("");
               error: function(errormessage) {
                    alert('Sorry message failed to send: ' + errormessage);
          • 2. Re: Receiving INPUT TEXT, making Forms from scratch.
            I believe you have to append a <input type='text'> to a <div> whether its a rectangle or a text box. Its html .
            • 3. Re: Receiving INPUT TEXT, making Forms from scratch.
              The newer versions of Edge Animate (v2+, v3) doesn't seem to support some of the old syntax I've put up here, setting the value of an input text field needs changing from .attr("value") to .val() i.e....
              to
              var name = comp.$("#InputNamei").val();
