4 Replies Latest reply on May 9, 2013 8:42 AM by TheImageLab
    Image Batch Processing stops on doc.saveAs()
    TheImageLab
      #target photoshop
      main();
      function main(){
      if(!documents.length) return;
      var startRulerUnits = app.preferences.rulerUnits;
      app.preferences.rulerUnits = Units.PIXELS;
      var doc = app.activeDocument;
      var Name = doc.name.replace(/\.[^\.]+$/, '');
      var Path = decodeURI(doc.path);
      doc.convertProfile( 'sRGB IEC61966-2.1', Intent.RELATIVECOLORIMETRIC, true, true );
      createNamedSnapshot("Snap 1");
      doc.convertProfile("Working CMYK", Intent.RELATIVECOLORIMETRIC, true, true, false);
      doc.resizeImage(1500, undefined, 300, ResampleMethod.BICUBIC);
      var outFolder = Folder(Path +"/TIFF");
      if(!outFolder.exists) outFolder.create();
      var saveFile = File(outFolder +"/"+Name+"_1500px.tif");
      SaveTIFF(saveFile);
      revertNamedSnapshot("Snap 1");
      outFolder = Folder(Path +"/PNG");
      var saveFile = File(outFolder +"/"+Name+".png");
      SavePNG(saveFile);
      doc.resizeImage(500, undefined, 72, ResampleMethod.BICUBIC);
      outFolder = Folder(Path +"/500px");
      var saveFile = File(outFolder +"/"+Name+"_500px.jpg");
      SaveJPEG(saveFile,8);
      doc.resizeImage(150, undefined, 72, ResampleMethod.BICUBIC);
      outFolder = Folder(Path +"/150px");
      var saveFile = File(outFolder +"/"+Name+"_150px.jpg");
      doc.resizeImage(100, undefined, 72, ResampleMethod.BICUBIC);
      outFolder = Folder(Path +"/gif");
      var saveFile = File(outFolder +"/"+Name+"_100px.gif");
      SaveGIF(saveFile);
      app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
      app.preferences.rulerUnits = startRulerUnits;
      if(documents.length)
      var doc = activeDocument;
      var Width = doc.width.as('px');
      var Height = doc.height.as('px');
      var Max = Math.max(Width,Height);
      var Min = Math.min(Width,Height);
      var White = new SolidColor;
      White.rgb.hexValue = 'ffffff';
      backgroundColor = White;
      doc.resizeCanvas(new UnitValue(Max,"px"),new UnitValue(Max,"px"),AnchorPosition.MIDDLECENTER);
      doc.resizeImage(new UnitValue(Min,"px"), undefined, undefined, ResampleMethod.BICUBIC);
      doc.resizeImage(1000, undefined, 300, ResampleMethod.BICUBIC);
      var outFolder = Folder(Path +"/THD");
      var saveFile = File(outFolder +"/"+Name+"_THD.jpg");
      function SaveJPEG(saveFile, jpegQuality){
      jpgSaveOptions = new JPEGSaveOptions();
      jpgSaveOptions.embedColorProfile = true;
      jpgSaveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
      jpgSaveOptions.matte = MatteType.NONE;
      jpgSaveOptions.quality = jpegQuality; //1-12
      activeDocument.saveAs(saveFile, jpgSaveOptions, true, Extension.LOWERCASE);
      function SaveTIFF(saveFile){
      tiffSaveOptions = new TiffSaveOptions();
      tiffSaveOptions.embedColorProfile = true;
      tiffSaveOptions.alphaChannels = true;
      tiffSaveOptions.layers = true;
      tiffSaveOptions.imageCompression = TIFFEncoding.TIFFLZW;
      activeDocument.saveAs(new File(saveFile), tiffSaveOptions, true, Extension.LOWERCASE);
      function SavePNG(saveFile){
          pngSaveOptions = new PNGSaveOptions();
      doc.saveAs(saveFile, pngSaveOptions, true, Extension.LOWERCASE);
      function SaveGIF(saveFile){
      gifSaveOptions = new ExportOptionsSaveForWeb();
      gifSaveOptions.Colors = 256;
      gifSaveOptions.dither = Dither.NONE;
      gifSaveOptions.quality = 0;
      gifSaveOptions.matte = MatteType.SEMIGRAY;
      doc.exportDocument(gifFile, ExportType.SAVEFORWEB, gifSaveOptions, Extension.LOWERCASE);
      function createNamedSnapshot(name) {
      var desc = new ActionDescriptor();
      var ref = new ActionReference();
      ref.putClass( charIDToTypeID('SnpS') );
      desc.putReference( charIDToTypeID('null'), ref );
      var ref1 = new ActionReference();
      ref1.putProperty( charIDToTypeID('HstS'), charIDToTypeID('CrnH') );
      desc.putReference( charIDToTypeID('From'), ref1 );
      desc.putString( charIDToTypeID('Nm  '), name );
      desc.putEnumerated( charIDToTypeID('Usng'), charIDToTypeID('HstS'), charIDToTypeID('FllD') );
      function revertNamedSnapshot(name) {
      ref.putName( charIDToTypeID('SnpS'), name );
      executeAction( charIDToTypeID('slct'), desc, DialogModes.NO );
        • 1. Re: Image Batch Processing stops on doc.saveAs()
          pixxxel schubser MVP & Adobe Community Professional
          Does this works for you?
          function SavePNG(saveFile){ // save4WebPNG8(saveFile)
          var pngSaveOptions = new ExportOptionsSaveForWeb;
          pngSaveOptions.PNG8 = true;
          //pngSaveOptions.transparency = false;
          //pngSaveOptions.interlaced = false;
          doc.exportDocument(saveFile,ExportType.SAVEFORWEB,pngSaveOptions, Extension.LOWERCASE);
          • 2. Re: Image Batch Processing stops on doc.saveAs()
            Paul Riggott Level 6
            There were several problems, the main problem was that the snapshot was not getting created, please try this now...
            #target photoshop
            main();
            function main(){
            SaveTIFF(saveFile);
            SavePNG(saveFile);
            SaveGIF(saveFile);
            activeDocument.saveAs(saveFile, pngSaveOptions, true, Extension.LOWERCASE);
            gifSaveOptions.quality = 100;
            activeDocument.exportDocument(saveFile, ExportType.SAVEFORWEB, gifSaveOptions, Extension.LOWERCASE);
            executeAction( charIDToTypeID('Mk  '), desc, DialogModes.NO );
            • 3. Re: Image Batch Processing stops on doc.saveAs()
              TheImageLab Level 1
              Thank you the script is working!
              Sent from my Verizon Wireless 4G LTE DROID
              • 4. Re: Image Batch Processing stops on doc.saveAs()
                TheImageLab Level 1
                Thank you... I appreciate your help!
